Author Topic: Newbie needs advice - Engine start-up  (Read 475 times)
Offline Cdnchallenger
« on: June 01, 2011 - 08:46:58 AM »
When cold my engine will crank and crank and crank before it finally fires up. After running for a minute or two it will fire right back up easily. When I drive it to a show and it sits for an hour or so it sometimes takes forever to start again.
Is there a quick list of things a "Newbie" should be checking.
Please start with the obvious.
Thanks
Re: Newbie needs advice - Engine start-up
« Reply #1 on: June 01, 2011 - 08:53:15 AM »
Sounds like a carburetor that has no fuel or the choke is not working properly. What engine/carburetor do you have?
« Reply #2 on: June 01, 2011 - 09:58:49 AM »
if the heat crossover in the intake is not blocked you may be boiling all the fuel off so when you go to restart it there si no fuel in the carb & it has to refill it before it will run
