Author Topic: fiberglass shaker setup  (Read 6703 times)
Offline sixpackcuda
  • Six pack to go!!!
Re:fiberglass shaker setup
« Reply #15 on: July 24, 2002 - 07:57:59 PM »
I talked to the guy from AAR at Carlisle and the complete setup which includes the shaker setup is $1500. The only thing not included was the base plate which he said they would have soon. The only thing I noticed about the hood was the holes by the cowl were not open, looked a little cheesy. Could be opened up I guess. You can also get bolt on or pin on.
http://www.aarqualityfiberglass.com/products2.html
I want to ask them about their Cuda Elastimeric Bumper!
 8)
« Last Edit: July 24, 2002 - 08:00:48 PM by sixpackcuda »
http://www.sixpackcuda.us
In-Violet 70 Cuda 340 W/6 Pack
Mopar Rules!!
IF IT DOESN'T WEAR A STAR, IT'S NOT A REAL CAR!!
Offline Koolman
« Reply #16 on: July 25, 2002 - 12:12:20 PM »
Hey thanks for the info on the site...really appreciate it...
Later...
Get In, Sit Down, Shut Up and Hold On!!
Wanting to go faster....Going Broke......Taking Donations.....
Offline thecountmc
  • I'm a llama!
« Reply #17 on: December 25, 2002 - 12:52:25 PM »
 I have a couple times seen a fiberglass trim ring on ebay for about $200 unfortunately at the time I didn't write down who was offering it and I can't find it back again.  AAR, year one and I believe USBody all offer shaker scoops "as low as $150 to $300 depending on quality.  I myself have been thinking about making a low buck shaker out of a flat steel hood and was hoping someone out there could point me to trim ring manufacturers or a ebay member name that I could contact... either fiberglass or steel and  also if anyone out there with a shakar could give me the measurements to from front to back/ side to side to the edge of the ring so I would know exactly where to cut once I start this project that would be great!.
Thanks,
Offline gizzard-1
« Reply #18 on: January 02, 2003 - 01:38:26 AM »
Saw an aar fiberglass at the mopar nationals.  Looked well constructed. The only "problem" was that the rear vents are not open and need to be opened up.
2nd place is for the 1st place loser!
02 Ram Big and Red
73 'Cuda Yellow
70 Charger 500 Black
Offline mustardketchup
  • I'm a llama!
« Reply #19 on: January 02, 2003 - 07:03:54 PM »
thecountmc:
Try Ben Snobar's Northwest Performance.  The phone number is 360-943-6633 and he is located in Olympia, Washington.  This guy has a web site, but sometimes it is up, and sometimes it's down.  I bought a metal shaker-hood trim ring and the underhood bracing from him.  The trim ring quality was about a "7" on a scale of 1 to 10 (made in China), but its not bad (a little body filler and sanding will make it perfect).  The underhood bracing looks excellent - it fit to the underside of the hood real tight.  It should look factory original with some spot (or plug) welding.
I started converting my steel hood in early 2002, but got sidetracked on other body-related items.  I do have those measurements you need!!  When I get home this evening, I'll dig out the "cut-out" dimensions, along with pricing, e-mail address for Ben Snobar, and his web address.  I will post that information tomorow (01/03/03).  Hang on if you can!
Larry
  • I'm a llama!
« Reply #20 on: January 06, 2003 - 09:44:58 PM »
thecountmc:
     Here is the info I promissed you, albeit, 3 days late:
Ben Snobar's Northwest Performance.  12636 Waddell Creek Rd, Olypia, WA 98512.  (360) 943-6633.  Or you can visit their web site at www.shakerhood.com or e-mail them at nwperf@nwlink.com.
     The measurments you need are as follows, and they are the distances from the outer edge of the trim ring to the specified outer edge of the hood:
1)  12 1/2 inches.  Back of trim ring to back hood edge.
2)  15 3/4 inches.  Front of trim ring to front hood edge.
3)  14 inches.  From right or left edge of trim ring to right or left edge of hood.
     DO NOT CUT ON THE DIMENSIONS GIVEN ABOVE!!!!  Your actual cuts should be about 1 inch to 1-1/4 inches inside the above deminsions.  The above dimensions only tell you where the outside edges of the trim ring fall in relation to the outer edges of the hood.  There is a lip or a recesion on the underside of the trim ring.  This lip/recesion of the trim ring will sit on this "extra" 1 1/4 inches of metal; it is also where the trim ring studs poke through to bolt the ring to your hood.
     Also, dimension #3 is not that critical and varies (because the sides of the trim ring is not straight).  What you are really trying to do with dimension #3 is get the trim ring centered on the hood.  So if you get, say, 14 inches on the left side (with your measuring tape, lets say, 26 inches back from the left front hood corner), you should go to the exact opposite side of the trim ring (this time 26 inches from the right front hood corner) and take your right side measurement.  If you've centered the ring properly, your right side measurement will match your left side measurement.  By the way, it helps to flip the trim ring over when taking your measurements; the studs protruding from the bottom of the trim ring don't allow you to get a good measurement if it's not flipped over.
     I would strongly recomend getting, at the least, the "small" kit from Ben Snobar.  This includes the trim ring, the underhood brace, and a flanging Vice-Grip tool (flanges that above mentioned 1-1/4 inches of "extra" sheetmetal so the trim ring sits flush to the hood).  This kit costs $700 plus shipping.  Don't try to do the hood without using the underhood bracing; the hood will buckle without the brace if you go to close it.  The underhood bracing's inner hole also gives you another reference of where the hood should be cut.
     Take your time and be super careful before you cut anything.  Measure and re-measure, and look at how everything would be bolted together before you cut.  I found that the brace needed some triming, especially where the opening meets the trim ring, before I was ready to cut.  I also had to lightly file the jaws of the flanging Vice-Grip tool so it would make a smooth flange.  Test yours on some scrap flat sheet metal before screwing up your flat hood.
     I know my response, as usual, was lengthy.  But I want you to know what your getting into and how to do it correctly.  I was only able to do my hood from some very helpful people who took the time to give me instructions and measurements (thank you Sheila and Danny!!).  I hope this helps and feel free to post me back if you have questions.
Larry
P.S.  I hope you have a 'cuda/Barracuda, because that is what these measurements are for.  They could very well be different if you have a Challenger.
P.S.S  If anybody was wondering, a stock, flat 1971 Barracuda steel hood weighs 66 pounds!
« Last Edit: January 06, 2003 - 09:52:29 PM by mustardketchup »
Offline gizzard-1
« Reply #21 on: January 07, 2003 - 01:51:36 AM »
And a raisin bran is 76 pounds!
02 Ram Big and Red
73 'Cuda Yellow
