Author Topic: coil mounting  (Read 736 times)
Offline lime73
coil mounting
« on: June 02, 2011 - 07:43:26 PM »
anyone got a picture of a coil mounted on a dual plane m1 RB intake.  looks like it is going to hit distributor if you use mounting holes on intake?   Also anyone know a good plug wire set that has cut to lengths wires with both straight and 90 degree boots included for plug ends.
Re: coil mounting
« Reply #1 on: June 02, 2011 - 07:57:10 PM »
Can't help with the intake/coil question , but I used MSD wires, the straight boots can be bent to about 45 degs and you can buy extra 90 deg or straight boots. My set is black in colour. Hope that helps some?
Offline lime73
Re: coil mounting
« Reply #2 on: June 03, 2011 - 11:41:54 AM »
Sorry... meant to say coil is going to hit the fuel line from carb.  Using holley 750
Offline DocMel
Re: coil mounting
« Reply #3 on: June 03, 2011 - 12:28:13 PM »
Myself, regardless of the intake, etc, I mount my coils OFF the engine, typically on the inner fender wells:  Coils get VERY hot mounted on thier side, only an inch from the intake.  Regardless of how you desire to mounty, accel makes great 8mm, as well as MSD that are cut to fit
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: coil mounting
« Reply #4 on: June 03, 2011 - 10:22:23 PM »
take a look at these too. the wish bone style i have used and works well, the other looks like it work well also
wish bone 24.00
vertical mount 16.00
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
