rear wheel bearings oil?
Author Topic: rear wheel bearings oil?  (Read 1164 times)
Offline b5blueaar
  • Mad Max Cuda
« on: December 22, 2004 - 05:40:06 PM »
I am putting a 3:91 sure grip in the 74 cuda.
I am debating if I should change the inner axle seals?
Do the wheel bearing receive oil from the 3rd member? Or are these seals susposed to keep it all out?
When I dissasembled, one wheel bearing was very noisy and both had oil in them.
I put new wheel bearing in and packed with grease, but should I change the inner seal or is oil susposed to get to the bearings? (a local shop told me it is)
thanks
Re: rear wheel bearings oil?
« Reply #1 on: December 22, 2004 - 06:34:06 PM »
they do not oil from the diff the only lubrication is the grease packed into the brgs so if they is oil in the oil brgs the seals have failed a& need to be replaced
cudahob
« Reply #2 on: December 22, 2004 - 06:36:43 PM »
No, the seal keeps the 3rd member oil out of the axle bearings. Grease is for the axle bearings, oil is for the pumkin.
 :coffee: ahh
You beat me on that 1 CP  :laughing: by 2min
« Last Edit: December 22, 2004 - 06:39:48 PM by cudahob »
« Reply #3 on: December 22, 2004 - 06:48:33 PM »
No prob same answer at least !! :coffee:
Offline b5blueaar
  • Mad Max Cuda
« Reply #4 on: December 22, 2004 - 07:51:19 PM »
Ok, thanks to both.
I am on my way to the garage to change the seals. I already bought them, expecting this answer. :beer:
thanks again
