Author Topic: how much is this rebuilt 360 worth used?  (Read 1029 times)
Offline EMCD
« on: June 04, 2011 - 08:54:54 PM »
Dodge 360 complete and ready to install. Nearly $5,000 invested on completely rebuilt engine with documentation. Dynomation software projects 460 hp at 4,000 rpm sea level, never put on actual dyno. Will sell assembled and ready to go or will dismantle for your inspection and parts verification. NO WARRENTIES other than it is what it's claimed to be. Engine was built for 1967 Barracuda and run for approximately 300 miles (not even broke in), but now the car is being sold with original motor. First picture is from prior to running in vehicle but shows headers. There is an optional new truck oil pan and oil pickup.
Block casting # 4006830-360-7
 Heads casting # 3769974, heads from Indy part #ARO CY SB340 2.02 intake 1.60 exhaust with upgraded seals and locks, my machine shop changed the springs to match comp cam
 Cloyes 9-1103 timing gear and chain
 Melling M72HV AFJ02E01 A4 oil pump
 Professional Products 90012 Harmonic Damper
 Comp Cam CCA-CL20-223-3 Cam and Lifters Duration 268/280 Lift .477/.480 with matching lifters.
 SBM 5140 forged I-Beam Rods EAGSIR6123CB
 NASCAR Pro 142069 Pistons .030 over
 Edelbrock EDL-7576 AirGap manifold
 Edelbrock 1407 750 cfm carb
 Doug's ceramic headers for "A" body Chysler
 March pullies and brackets
 New alternator, water pump, and separate new unused truck oil pan and oil pickup
 Plus all of the other parts that are obviously to numerous to mention
THANKS YOU ADVICE.
Offline 70 rtse
Re: how much is this rebuilt 360 worth used?
« Reply #1 on: November 04, 2012 - 03:42:58 AM »
i may be intrested how much you want
Offline EMCD
« Reply #2 on: November 04, 2012 - 11:42:59 AM »
The motor blew up. The bore was misaligned.
Offline tman
« Reply #3 on: November 04, 2012 - 01:06:34 PM »
Now that does not make sense.  Was that last note something that should have been said in the first posting?
Offline tman
« Reply #4 on: November 04, 2012 - 01:07:52 PM »
Ooops, now I see first posting is over a year ago.
Offline EMCD
« Reply #5 on: November 05, 2012 - 01:26:42 PM »
It was brutal experience and I'll never buy a used engine again. Safer to complete the rebuild yourself. At least you will know its true lay built.
