Author Topic: Test my Tach Question....  (Read 969 times)
Offline Morris'_Mopars
« on: June 06, 2011 - 10:47:11 PM »
I have factory ralley gauges in my 71 barracuda. The tach currently does not work. How can I check to see if the tach is any good??? :clueless:
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Offline Grec
Re: Test my Tach Question....
« Reply #1 on: June 08, 2011 - 05:25:03 PM »
Is it currently disconnected? It's a pretty simple setup... the line from the tach runs straight to, I believe, the negative post on the ignition coil.
I finally got around to hooking mine up a couple weeks ago, and voila... it works. :-)
There should be a single line running from the dash, through a rubber grommet in the firewall. General area of behind the clutch pedal in a manual. (Mine is a '73 so your setup may be a little different)
Not sure if the gauge cluster needs to be powered for the tach to work, though...
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
« Reply #2 on: June 08, 2011 - 05:52:11 PM »
I don't know of a real good way to test it, other than taking it out of the car. There is a long screw where 12 volts will be supplied. There is a tab to get the "-" signal from your ignition coil. I just hook it up under my hood. I run wires to my coil and ballast resistor for power, then I take one of the screws out of the question, and run a ground wire to anyplace handy. A valve cover bolt for instance. For what it's worth, if this is the original tach, it went to heaven long ago. It is common for them to die.
Offline ShelbyDogg
« Reply #3 on: June 12, 2011 - 12:40:32 PM »
You migth want to upgrade it with the R-T-engineering solid state tach board anyway.  My stock 8 grand tach displays 3000 rpm, when my computer shows 2100 RPM.  Which one would you trust?
