Author Topic: 727 Fluid Capacity with MP deep trans pan  (Read 1438 times)
Offline wally426ci
    • maryland mopars
« on: June 07, 2011 - 02:24:26 PM »
I've asked this question before and Terry gave me the answer but I cannot find it in search results.....
I just fixed a few leaks and I need to refill, I don't think the converter lost any fluid but a little is possible....
Anyone know how much this puppy holds? 8 qts?
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline barracuda7199
  • needs a resto but having to much fun right now
Re: 727 Fluid Capacity with MP deep trans pan
« Reply #1 on: June 07, 2011 - 09:20:42 PM »
that should get u in the ballpark. might grab an even 10 even u don't need it now it will be on the shelf.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline wally426ci
    • maryland mopars
« Reply #2 on: June 07, 2011 - 09:28:37 PM »
Thanks! I have 2 gallons, so I will see how far that goes. I need to move it out of the garage soon so I'll let everyone know.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #3 on: June 12, 2011 - 11:20:31 AM »
4 qts should be close , if the converter is still full you will not need a lot
Offline Dusty1
  • Revived
« Reply #4 on: June 02, 2013 - 04:53:53 PM »
Is there anyway to get all the fluid out? I am considering putting Trick Shift fluid in.
Garys 1972 BS
Offline 72cudamaan
« Reply #5 on: June 02, 2013 - 08:55:30 PM »
Not unless you have a drain plug in your convertor. By the way B&M Trickshift is supposedly just Type F fluid. Just an FYI
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Dusty1
  • Revived
« Reply #6 on: June 03, 2013 - 09:27:00 PM »
That's what I thought, but I thought you might have some magical Mopar trickery that no one else knew about. Thanks
Garys 1972 BS
Offline challengerx
« Reply #7 on: June 03, 2013 - 10:33:08 PM »
I had the same question awhile back, so which is it 8,10 or 4 quarts.
Offline cudabob496
« Reply #8 on: June 18, 2013 - 05:38:31 AM »
I'd use synthetic tranny fluid. Been using it for 10 years. Tranny running great, and cooler.
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #9 on: June 18, 2013 - 08:59:06 PM »
I've run Type F in all my mopar transmissions and never had a problem. Even hooked up a trans temp gauge
and never ran hot. It's all in the trans coolers I use evidently. I always bypass the radiator.
Offline cudabob496
« Reply #10 on: June 19, 2013 - 01:05:45 AM »
Well, I would guess that if you ran 1000 trannies hard for 100,000+ miles, and half had synthetic, and half
had dino juice, you would see fewer problems with those with synthetics.  Simply due to synthetics
lubricating better and lowering operating temperatures. The number one killer of trannys is heat.  But each to his own, as we have been going
back and forth on this issue for years.  Run what'ya brung!
2011 Kawasaki Z1000
