Author Topic: No interior/instrument lights "title edited to show new problem"  (Read 1855 times)
Re: No interior/instrument lights "title edited to show new problem"
« Reply #15 on: June 11, 2011 - 02:09:42 PM »
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #16 on: June 11, 2011 - 02:55:13 PM »
glad you got it solved  :2thumbs:
72rtchallenger
what happens in the garage
stays in the garage
Offline JayBee
« Reply #17 on: June 11, 2011 - 04:55:50 PM »
None better that Brother Slotts  http://www.cuda-challenger.com/cc/index.php?topic=64880.msg773679#msg773679
 :iagree:  totally! He's done 3 out 4 of mine and I'm more than satisfied. As soon as I get a spare "Top Lift" he'll be doing that one too.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Barracudadan
« Reply #18 on: June 11, 2011 - 06:46:39 PM »
Just got back from a short cruise around town lights all working good.I will have to get in touch with slotts for a switch. Easy to see his stuff is top notch I may need a dimmer as well not sure if it`s bad I`ll get the headlight switch first before I pronounce the dimmer dead.
I did notice on my ride my temp gauge is working now, so buying the voltage limiter wasnt a waste of time for me! :bigsmile: Which leads me to believe I`ll be taking out my sending unit to get the fuel gauge working.
I had an idea that worked out pretty good for jumping the dimmer switch I don`t know if anyone else tried this so I`m taking all the credit. Lol! I took a fuse the kind you find in modern cars gently bent the prongs to line up with the dimmer switch plug it fit in there perfectly. So now I have a jumper with circuit protection built in just in case anything decides to go wrong!
Offline 422STROKER
  • Member Since 6/3/06
« Reply #19 on: June 11, 2011 - 09:55:56 PM »
SUCCESS!  :woohoo: :woohoo: :woohoo:
Turns out after all that the headlight switch was bad and it only took 5 days to figure out! :faint:
I ended up wrapping  some copper wire around the bottom 3 contacts of the switch to get the lights on. Even then the dome light didn`t come on so I pulled out the bulb to check it and when I was putting it back in my hand slipped and I shoved the bulb in hard and the light came on.  :bigsmile:
All this was to get at my voltage limiter to get my fuel and temp gauges working and after putting in the new limiter from dashworks my gauges still don`t work!  :banghead: I`m gonna save this problem for another day. At least I get the peace of mind knowing I wont fry my gauges
So now where can I find a new headlight switch?
Member Slotts refurbishes them.  Excellent pieces.
Tom
Tom
