Author Topic: Spark plugs + anti-sieze lube  (Read 1299 times)
Offline jforest1
« on: June 10, 2011 - 10:17:00 AM »
Do you guys generally use anti-sieze lube on your spark plugs?  I read somewhere that if the plugs are nickel or have been pre-coated one shouldn't lube them because the anti-sieze acts as a lubricant and would allow for more torque to be applied than should be.   :clueless:  Not sure if there's validity in that statement or not.
I was wondering if I should apply some to my plugs after my exhaust stud debacle...   :eek4:
JF
« Last Edit: June 10, 2011 - 10:26:59 AM by jforest1 »
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: Spark plugs + anti-sieze lube
« Reply #1 on: June 11, 2011 - 10:00:36 PM »
Aluminum heads?  If so, I use never seeze.
Offline footin70rt
« Reply #2 on: June 12, 2011 - 02:24:49 AM »
Aluminum heads definitively use anti-seize. Will not hurt anything if you use it on cast iron heads either, I use anti-seize all spark plugs just for good measure no matter what the head material.   :2cents:
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline ShelbyDogg
« Reply #3 on: June 12, 2011 - 12:37:05 PM »
Me too.  Anti seize on all of my spark plugs in all cars.
Offline jforest1
« Reply #4 on: June 13, 2011 - 09:49:38 AM »
Thanks guys!
JF
