Author Topic: engine oil supplements??  (Read 4423 times)
Offline ireland383
Re: engine oil supplements??
« Reply #15 on: June 11, 2011 - 12:13:26 PM »
Shell Rotella T 15/40 still has 1200 ppm of Zinc.  Nice and cheap also!
1971 Plymouth Barracuda
Offline Katfish
  • 70 Challenger
« Reply #16 on: June 11, 2011 - 12:20:49 PM »
Anyone have a site that shows the zinc content of these oils for comparison?
All I see are links to the Bob's the Oil Guy site, too much reading for me.  Is there a Zinc Content Chart for Dummies?
Offline Strawdawg
    • Vortex Buicks
« Reply #17 on: June 11, 2011 - 07:41:08 PM »
here is a partial list....does not have a lot of the specialty oils, but some
http://www.s10planet.com/forum/showthread.php?t=26062&page=1
Offline Katfish
  • 70 Challenger
« Reply #18 on: June 12, 2011 - 08:40:24 AM »
This stuff looks pretty good, and I can get it locally.
http://www.barsproducts.com/tech/4401_tech.pdf
Brings the Zinc to >1600ppm
Offline Katfish
  • 70 Challenger
« Reply #19 on: June 16, 2011 - 06:05:55 PM »
After some more research I have decided to go this route.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_TB-Zinc-Plus-Engine-Break-In-Oil-Additive-(16-oz-)-Lucas-Oil-Products_7660006-P_N2049_T%7CGRP60033_____
Lucas additive has 35,000ppm Zinc, just need 4oz (1/4 bottle) to bring regular oil up to >1200ppm.
I can pick it up locally at Advanced Auto for about $12 (normally $14 but if you order it online, they always have a 20% off)
Now an oil change will be <$20 with the filter included.
« Last Edit: June 16, 2011 - 07:27:38 PM by Katfish »
Offline 4Cruizn
  • HEMI FISH
« Reply #20 on: June 16, 2011 - 08:15:46 PM »
So is 1200ppm the minimum level needed?   :clueless:
Offline Strawdawg
    • Vortex Buicks
« Reply #21 on: June 16, 2011 - 08:21:11 PM »
That is the historical levels of good oil.  If you are running very high pressure valve springs, then I would consider adding a supplement
Offline Katfish
  • 70 Challenger
« Reply #22 on: June 17, 2011 - 04:49:28 PM »
I did a few calculations, and 4oz of additive to normal oil with 800ppm Zinc will bring it up to >1600ppm   :2thumbs:
10-40W        Lucas             Lucas         Oil (Qts)         PPM
PPM            PPM                 oz               5                    effective
800             35,000           16               4.50                4220
800             35,000           15               4.53                4006
800             35,000           14               4.56                3793
800             35,000           13               4.59                3579
800             35,000           12               4.63                3365
800             35,000           11               4.66                3151
800             35,000           10               4.69                2938
800             35,000           9                  4.72                2724
800             35,000           8                  4.75                2510
800             35,000           7                  4.78                2296
800             35,000           6                  4.81                2083
800             35,000           5                  4.84                1869
800             35,000           4                  4.88                1655
800             35,000           3                  4.91                1441
800             35,000           2                  4.94                1228
800             35,000           1                  4.97                1014
Offline polarbear123
« Reply #23 on: June 20, 2011 - 12:53:28 PM »
For what it is worth I was told that after market additives were not as effective as the additives that are blended into the oil. That came from a Brad Penn rep
Offline JayBee
« Reply #24 on: August 16, 2011 - 06:51:34 PM »
My motor was just rebuilt (July 2011) and the rebuilder recommended Shell Rotella T 15w40 and half a bottle of Comp Cams Engine Break In Additive (6 oz) for each oil change.
« Last Edit: August 16, 2011 - 07:03:34 PM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline bandt
« Reply #25 on: August 16, 2011 - 07:13:55 PM »
I use the Valvoline Racing oil.
Wish I had the link but a guy on another forum paid to have an independent company test a few different oils and the VR-1 came out very well for those of us with flat tappets. I can get it locally and its not insanely expensive.
Brian
Offline aris_unlimited
  • Project in full swing
« Reply #26 on: August 16, 2011 - 07:35:09 PM »
Anyone use Mystik or Royal Purple? The guy who had my car before me swore by Mystik.   Matt
I used to use royal purple and it seemed ok, although it did make my car run differently (almost like it had to work a little harder than it used too). Before that I always used mobil 1, just wanted to give the royal purple a try. I'm back to mobil 1 now. There is a guy around here that races professionally and he was talking to me about royal purple vs mobil 1 one time. He said he has never had an engine fail using mobil 1, but he has with royal purple. That was good enough for me lol.
Cuda is gone :(
74 satellite, daily driver/project now
