Author Topic: Driver side backfiring  (Read 1378 times)
Offline jforest1
« on: June 10, 2011 - 07:51:11 PM »
I've done my alternator upgrade and put the exhaust manifold back on to make sure everything is good electrically.
So running open exhaust manifold, I'm backfiring driver side at ~2000rpm. I triple checked the spark plug cables are correct.
I'll probably switch out the spark plug sides tomorrow morning after the engine cools and see if the backfiring moves to the passenger side.
If it were running rich it would be backfiring out of both sides, correct?
Any other reasons why backfiring out of one side only might be happening?
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: Driver side backfiring
« Reply #1 on: June 10, 2011 - 08:14:38 PM »
There could be a leak. Try to tighten the bolts on the exhaust manifold again.
Offline jforest1
« Reply #2 on: June 11, 2011 - 09:47:16 AM »
What kind of leak?
I tightened to 120 inch pounds from the manual, but I made an educated guess at which bolts they were referring to.  Is that correct?
JF
« Reply #3 on: June 12, 2011 - 08:59:46 AM »
is the engine runnig smooth ?
if si with the manifold open the extra fuel in the manifold my be burning as it hits the oxygen at the manifold opening . Other possibilities are it is rich or lean at that RPM
Offline jforest1
« Reply #4 on: June 12, 2011 - 04:55:54 PM »
Yes so switched out the plugs and now both sides are backfiring.  I'm thinking I didn't have a good vantage point last time on the driver side and now am doing it but probably was both sides before.  So I'm thinking now it's just running a bit rich as ambient temperature is much hotter.
JF
Offline jforest1
« Reply #5 on: June 27, 2011 - 10:59:28 AM »
Just to close this up, I've put the pipes back on and it is no longer backfiring.
JF
Offline mojavered
  • Someday!
« Reply #6 on: June 30, 2011 - 08:29:00 PM »
Sounds like it was a back pressure problem?
Jason
