Author Topic: Metro vs. Soft Seal  (Read 7657 times)
Metro vs. Soft Seal
« on: June 10, 2011 - 11:41:17 PM »
After installing the Metro trunk weatherstrip, I looked at it thinking to myself...
"It sure is thick, hope it works!"
Well it didn't!  :swear:
My trunk lid stood up a 1/4" all the way around preventing me from final blocking.
Just received the Soft Seal and I can already tell it is much thinner and shouldn't create trunk lid setting/alignment issues.
Thought I'd throw this out to pre warn others.
Offline Cuda Cody
  • Vancouver, WA
Re: Metro vs. Soft Seal
« Reply #1 on: June 10, 2011 - 11:57:34 PM »
Same here... I installed Metro and had to remove it.  Went with Soft Seal and it worked great.
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #2 on: June 11, 2011 - 10:38:43 AM »
I got my trunk seal from Year One which I think is supplied by Metro.  It fits great, being only slightly "fatter" than the 41 year old one I pulled off.  Maybe Year One uses someone other than Metro for their trunk seals. I was weary of a potential problem because I had recently been to Fenders and Fins and they were having trouble with a "fat" trunk seal.  I don't know who supplied that one.  PK
The Brewmaster
« Reply #3 on: June 11, 2011 - 10:41:45 AM »
I have both now so I can take pics and show a comparison.
When I get back tonight I'll show them how they compare against each other.
« Reply #4 on: June 12, 2011 - 12:52:48 AM »
Here's the pics,
Quite a difference in durometer and shape,
Using tape, I put on the weatherstrip. This way I can re use it. The trunk still needs a slight adjustment. It's way better  than it was before with the Metro.
Uploaded with ImageShack.us
Offline JonS
« Reply #5 on: June 12, 2011 - 03:58:43 PM »
TC,
Where did you purchase the soft seal from?
Jon
« Reply #6 on: June 13, 2011 - 12:34:56 AM »
RPS Restorations Hayward, CA. right near me.
Tony even delivered it to my doorstep personally. Excellent CS.
« Reply #7 on: June 13, 2011 - 09:53:06 AM »
I've heard of people taping cardboard to the trunk lid where the weatherstripping hits it.  When the lid is closed, it will over compress the seal.  After a few days, the cardboard is removed and the trunk should shut much better.
My car was blocked with the weatherstripping inplace.  Unfortunatly, the weatherstripping was the same as the pictures above...incorrect for 73.  Once I find the correct one(If I can find the correct one) I may have to use the cardboard trick.
Offline resq302
« Reply #8 on: January 10, 2014 - 08:53:30 AM »
Here's the pics,
Topcat,
Which one in your pic is the Softseal?  The bottom one?
« Reply #9 on: January 10, 2014 - 09:37:53 AM »
Yes.
Offline resq302
« Reply #10 on: January 10, 2014 - 01:41:52 PM »
Thanks!
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #11 on: January 11, 2014 - 05:36:53 PM »
Good info!!
Daniel
www.ebodyproducts.com
Offline anlauto
« Reply #12 on: January 11, 2014 - 06:33:12 PM »
I'm still working on the bulk 500ft roll I bought from Dales Cuda Shop. Not sure their manufacture, but it's excellent stuff, never had a problem wiith it :2cents:
« Reply #13 on: January 11, 2014 - 08:53:39 PM »
The Softseal; although it looks thinner is height, seals very well on my trunk lid.
Passed the water test.
Softseal is an excellent product.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #14 on: January 12, 2014 - 04:16:34 PM »
DMT makes/sells a trunk seal that is supposed to be correct regarding durometer at least; not sure about the profile though.  Everything I have purchased from them has been top-notch stuff.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
