Author Topic: Two Holley Questions?  (Read 522 times)
Offline CUDA JAS
  • vroooooom!
« on: June 11, 2011 - 12:52:55 AM »
Does anyone now if the newer Holley carbs come standard with reuseable gaskets????? I do not want to pull it a part and have to buy new bowl gaskets.
Also, I unbolted my carb and it rocks abit on the intake. I suspect the baseplate is warped a little, which I assume is bad, or is a little wobble normal????
Thanks,
Jason
74 'cuda 360/727
Just call me a gearhead!
Re: Two Holley Questions?
« Reply #1 on: June 11, 2011 - 07:42:56 AM »
Thanks,
Jason
Check the linkages for clearance issues , maybe causing the rocking. Make sure the butterflyies open without hitting too. I had the choke linkage rubbing on the intake, two seconds with a airgrinder/carbide burr and all was good to go.
The reuseable gaskets for Holley's I've seen are blue or red.
Also check acellerator pumps and linkages for clearance too.
« Last Edit: June 11, 2011 - 07:46:04 AM by brads70 »
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: June 11, 2011 - 09:12:01 AM »
Thanks brad...yeah I will have to take a close look at everything on the new intake.
I think the carb base may be warped though.  It does not wobble a lot, but its noticible.
On the gaskets, I can see the blue gasket on the float bowls, so maybe....
Jason
74 'cuda 360/727
