Author Topic: The right part....or a part that will work...  (Read 970 times)
Offline CUDA JAS
  • vroooooom!
« on: June 11, 2011 - 09:50:49 PM »
So which one do you go with....
I have learned over the last couple of years, from fixing other's, and my younger mistakes, that it usually pays to go with the right part, even if it costs a bit more or takes more time to find/get.
Here is my current example, small block heater hose nipples for an intake swap.
I can pick up some brass NPT fittings that will work or I can order the right parts from Mancini, and wait for them to come through the post to the Great White North. The right part only costs a little bit more.
Hmmmm.....I am not so sure I want to wait and follow my own advice.
What to do what to do.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline AARCUDADEN
Re: The right part....or a part that will work...
« Reply #1 on: June 11, 2011 - 10:21:07 PM »
I know exlackly what you mean been there myself. Anymore if i know it will work and costs less thats usually the way i go  :grinyes:
Dennis,Ohio
« Reply #2 on: June 12, 2011 - 12:23:00 AM »
With the postal strike going on...... UPS?
Offline CHL2T
  • Handle it, man!
« Reply #3 on: June 12, 2011 - 12:27:43 AM »
 If my local true value or auto parts store don't have it, then I'll order it
Offline Aussie Challenger
« Reply #4 on: June 12, 2011 - 06:31:02 AM »
In this case I would go with the brass fittings.   :bigsmile:
Offline Grec
« Reply #5 on: June 28, 2011 - 03:12:25 PM »
I try to keep my engine compartment looking as factory-chrysler as possible, so my general rule of thumb is that if it's going to be plainly visible, I use a "correct" part.
That said, on something like a hose nipple, as long as it would be covered by the hose and hidden, I'd consider a shortcut. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
