Author Topic: rally light bar, neutral safety switch issue  (Read 1081 times)
Offline 7samurai
« on: June 13, 2011 - 02:07:48 PM »
my rally light bar has a corroded light socket. cannot seem to find replacement. bulbs are plentiful. any idea?  I installed new harnesses (rebuilt dash harness off of ebay) front to rear and I hooked up a battery to the bulkhead hot wire (fused of course).  engine is not fully wired yet.  My lights all work fine and I got the road lamps to work.  I hooked up a new neutral safety switch and made a harness. bought new dash terminal connector and trans terminal.  should have bought the whole thing from penstar. grounded the brown wire, but still have no backup lights when I shift into reverse with ignition on.  correctly wired to the connectors on the firewall according to the wiring diagram.  anything I am missing? thanks.
Re: rally light bar, neutral safety switch issue
« Reply #1 on: June 14, 2011 - 04:54:20 PM »
I had trouble with my reverce light too, just needed a cleaning with sandpaper at the socket to housing to ground it then it worked.
Offline 7samurai
« Reply #2 on: June 14, 2011 - 06:32:05 PM »
thanks for the input.  I have a new rear light harness and new bulbs, so I do not think that is the issue.   Also new bulkhead connector and trans switch connector.  not a priority, so will fuss with it when I have time.
« Reply #3 on: June 14, 2011 - 10:31:00 PM »
With the car off put it in reverse, then take a wire touch one end to the steel socket then the other end to bare metal somewhere on the body and see if the light comes on. That's how I discovered mine?
Offline ShelbyDogg
« Reply #4 on: June 19, 2011 - 11:52:49 PM »
Reverse light should come on when the 2 ouside wires ar touched together on an automatic's neutral start switch, Or 2 wires shorted together on a manual tranny's reverse switch. One wire is 12v the other goes righ to the reverse light,  Use a test light and start at the blukhead 12v supply side.
