is really is not that hard to do , there is 3 parts in each hole , the bottom pin , top pin & spring , if you transfer the ones from your old locks it should work but the pins may be badly worn , you may have the coorect length pins in the new locks , but you have to keep the bottom & top pin together as a set , the longer the bottom pin the shorter the top pin or the stack becomes to tall to work
