Author Topic: Paint Stripping  (Read 4194 times)
Offline mopar316
  • I love YaBB 1G - SP1!
Paint Stripping
« on: May 16, 2002 - 06:00:33 AM »
I have tried various brands of paint stripper, and am presently using POR-15. It removes the paint fairly well, but some of the primer it won't remove. I have had this same problem with the previous brands I used also. Can anyone give some advice on this subject?
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Paint Stripping
« Reply #1 on: May 16, 2002 - 07:42:55 AM »
We had to strip our hood by hand and used Bix.  It was tough getting the primer to come off, but with a lot of elbow grease, it turned out great.
Offline camjam
  • Rare-it-T
Re: Paint Stripping
« Reply #2 on: May 16, 2002 - 08:46:58 AM »
I have heard of using airplane paint stripper. I am told it is very potent and needs a super amount of ventilation.
I was watching speedvision some time ago and there was a segment on stripping paint. What they did was they applied the paint stripper and then taped plastic (black garbage bag) over the area to prevent evaporation and left it for a few hours. I can't remember the time frame right now. I taped the show and I'll see if I can find the segment. Otherwise you would have to experiment with the time for the best results. I would be interested in your results.
71 Challenger R/T 383 4spd - 1 of 10 known to have been built for canada - restored
70 Charger R/T SE 440 auto - restored
Offline heminut
Re: Paint Stripping
« Reply #3 on: May 16, 2002 - 10:36:09 AM »
I have used the Aircraft Paint Stripper that camjam is talking about. I don't know about the primer you're having problems with, but it worked good on black wrinkle paint when the other strippers didn't.
1970 5.7 Hemi Cuda
Offline Keitho
  • Newbie
  • I'm a llama!
Re:Paint Stripping
« Reply #4 on: July 05, 2002 - 09:43:44 PM »
Hey gang, im brand new to this site, but come from across the way from Charger.com boards. I'm interested to know more about the Barracudas....but anyway...on to paint stripping. I've nearly finished removing the paint from my Charger...3 primer layers, and 3 paint layers...pretty thick amount to strip by hand, let me tell you. >:( I use the "Aircraft Stripper" available at most aotomotive stores. Use a 3" paint brush to apply it to the surface in nice heavy coats, go in one direction only, as this stuff has a formulated anti-evaporation additive in it that gets all screwed up if you brush back over it. Do it on a warm day, but avoid doing it in direct sunlight as it will boil REALLY FAST. If you strip indoors, make sure you got ventilation. Wear gloves...it can remove your skin too! After it sits a little while...it will begin to bubble or liquify, or both. You're good to go at this point....grab a 2" metal putty knife and start scraping! Makes a mess, but does a great job overall. I reccomend a D.A. with fine grit for your "clean-up sanding". Just to remove the last traces of primer, or whatever. Also, this stuff will soften bondo, so if you want to save yourself bodywork, avoid heavy use where filler is present. Hope this helped! I'm off to check out the members rides and see some cool Cuda's! Later goys!
