I assume this is a solid flat tappet not a roller ? Actually your cam is as big as the ones I use ,the duration profile is the same or slightly longer than the cam I used even though the lift is less , lift really doesn't count , it doesn't affect the way the engine runs , you will have about 8" of vacuum I believe possibly a bit higher using the 112 CL , although I am not sure why you went with that unless you are running iron manifolds , a similar Lunati cam would have been over .580 lift
