with DP if you can snap the throttle 25% with no bog leave the front squirter alone concentrate on the rear squirter .
the squrter controls the speed that the fuel is delivered , the cam controls the volume of fuel so if the bog is instantanious the squirter is too small , if it starts to go & sags for a second the cam is not delivering enough fuel .
there are 3 types of squirter , the tube type worst as the air flow can draw in fuel @WOT , the type you have which is marginally better , & the box type best as no fuel can be drawn in with air flow past it
