I posted a chart on that thread. Let me know if it is no longer there. Depending on the engine parts casting years etc., you can use the crank, which should be forged, from the 273 in the 318. That will give you a strong foundation. I have a 318 here that has the forged 273 crank, the larger 340 rods (also on newer 318's), the 340 heads, and the 340 windage tray. A set up like that will give you a decent motor that is not real expensive. You can even get decent gas mileage out of it depending on your cam selection.
