Author Topic: A couple of Shaker questions  (Read 641 times)
Offline 06Daytona
« on: June 15, 2011 - 07:11:40 PM »
I'm doing a dry run putting the Shaker together and I'm finding that the cold and warm air doors are binding a little. Neither door is closing all the way when I use the short cable. Is it better to shave a little out of the inside of the bubble, or can I get away with adding a couple of washers between the door mechanisms and the bubble itself? The hot/cold air door connector bar seems to bind a little as well, but it might be because of the doors binding so I'm planning on tackling one issue at a time.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Re: A couple of Shaker questions
« Reply #1 on: June 16, 2011 - 05:35:28 PM »
the repro parts never seem to work 100% , I would clearance the the bubble a liitle or trim the door itself , the hot cold door you will likely never really use anyway in a warm climate
Offline 06Daytona
« Reply #2 on: June 16, 2011 - 05:52:15 PM »
I actually ended up taking a little out where the cold air hinge was hitting the bubble, and I added a few washers in various configurations until I got it working pretty well. I'll probably have the cold air open most of the time here, but I'd like to have it all working properly just cause it's cool
