Author Topic: Reproduction 71 Cuda Grilles  (Read 52278 times)
Offline 2TAGS
Re: Reproduction 71 Cuda Grilles
« Reply #210 on: May 04, 2013 - 04:01:20 PM »
Easy answer...Your car has a 1973-74 header panel. They switched the directions of the slots for some reason. Your only solution would be to use nuts/bolts or a screw and a clip nut.
You should also have a reinforcement plate on the verticle upright for mounting the horns (73-74) that's the quickest way to tell them apart. :2cents:
:banghead:
Thanks for the quick response!  I'll do some checking....
1971 'Cuda 340
