360ci, Edelbrock 650 carb, Electronic Ignition.
The engine will not idle unless I open the throttle to about 1500rpm. Anything above 1500rpm and the motor performs well but the moment I let off the throttle to allow the engine to run on Idle circuit then it dies instantly.
I have done no mods to the engine/carb, this symptom came on quite suddenly. I've tried a new fuel filter/fuel pump/adjusted the idle mixture screws but nothing seems to help. I've pulled the plugs and they appear on the lean side.
I plan on removing the gas from the tank and starting with new, this gas is probably a year old. Any other suggestions would be appreciated.
Thanks
