Author Topic: FAST ez efi install... waaay too much fuel pressure. any ideas  (Read 1911 times)
Offline challngd73
Installing the fast ez efi on my 440.  Problem is the fuel psi gauge is showing 80 psi, and we cant get it to drop.  Is it the fuel pump?  the regulator?  any thoughts welcome.   thanks.
Offline Strawdawg
    • Vortex Buicks
Re: FAST ez efi install... waaay too much fuel pressure. any ideas
« Reply #1 on: June 16, 2011 - 02:33:51 PM »
something on the return side is restricting the flow back to the tank.  Make sure the return line is open from the regulator back to the tank.  next step would be to see if the regulator is stuck in the closed position.
Offline challngd73
« Reply #2 on: June 16, 2011 - 02:39:31 PM »
Its a brand new 3/8 return line from regulator to tank.  How do i check if the regulator is stuck?
edit: I dont think it can be stuck as we had sprung leaks after it, thats why we got the new return line.
« Last Edit: June 16, 2011 - 02:44:18 PM by challngd73 »
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: June 16, 2011 - 06:08:55 PM »
take it apart
Offline challngd73
« Reply #4 on: June 16, 2011 - 11:04:32 PM »
Ok, update.. Took the return line off at the tank and let it empty into a bucket.  The pressure went down to where it should be, so that would mean the obstruction is in the lines going into the tank.  Any thoughts on how to clear it?
Offline the_engineers
« Reply #5 on: June 16, 2011 - 11:07:41 PM »
Is the return submerged?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: June 16, 2011 - 11:20:23 PM »
if it emptied into the bucket, then the problem is not in the line...takes you to the tank.
If you remove the tank cap, does it work properly?  If not, you are going to have to pull the sending unit/pick up and follow the path thru it.;
Offline challngd73
« Reply #7 on: June 17, 2011 - 02:49:31 AM »
Sorry, I meant to say the tank.  Thanks for the suggestions.  I'll give them a go tomorrow.
Offline challngd73
« Reply #8 on: June 17, 2011 - 08:36:23 PM »
The vapor separator was the choke point.  It hasnt been hooked up since I had the car(no canister), and seems to have seized up inside.  We bypassed it, blocked off a couple of the lines coming out of the tank and used one as a vent, with fuel line and a filter.  Also have a vented gas cap.  Seems to be working fine.  Wanted to thank you all for your help.
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: June 17, 2011 - 09:39:21 PM »
glad you sorted it out... :)
