Author Topic: Transmission Cooler mounting location other than in front of radiator...  (Read 4365 times)
Offline Cruzin
  • I love YaBB 1 Gold!
Ideas please... for mounting an automatic transmission cooler in a functional area other than obsuring radiator.   Car is a '73 Challenger.  I have not purchase the tranny cooler so I have some flexibility as to the cooler's size and shape.
I made two brackets mounting to the rad saddle, thenm mounted the tranny cooler and a power steering cooler to it. It's 2-3" away from the rad.
Offline crash340
Brad,
did you run hoses from teh cooler all the way back to the trans? adn if you did, did you just use hose clamps, I have just installed TTI's on my 340 and the trans cooler hard lines need to go as they are just in the way all over the place.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
http://www.summitracing.com/parts/der-13225/overview/
or, you can mount it away from radiator, but have a small fan
attached to it to aid cooling.
http://www.summitracing.com/parts/sum-g4890/overview/
« Last Edit: April 25, 2014 - 06:46:20 AM by cudabob496 »
2011 Kawasaki Z1000
Brad,
Greg
No the steel hard lines run up to the valance. Rubber from there.
Offline Strawdawg
    • Vortex Buicks
It needs to be mounted such that an adequate amount of air passes thru it when moving...otherwise one of the B&M Hi-tek coolers will work, but they ain't cheap unless you compare them to the cost of a new tranny.  Use the largest one you can mount if you live in a hotter part of the country.  Up north, it's not such a problem.
Offline drewcrane
I had an issue with cooling ,first mounted them(oil  and trans cooler) in front of the rad, the car ran hot,
 I relocated and angled them with some angle aluminum ,now they work very well and it gets up to 100 f here in the summer and have traveled two long desert trips and never had a cooling issue
Offline crash340
Thanks Guys, appreciate the input.
Does anyone know the size of the fittings that screw into the trans housing please, I'm thinking I will go to flex lines (from trans to cooler) and AN- fittings rather than hose clamps
Greg
Greg
73 Cuda
Brisbane, Australia
Offline Katfish
  • 70 Challenger
Following along, need to do this when I do my 518 install.
Offline Kapteenikosmos
Greg
1/8" npt if my memory serves me right
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline crash340
Re: Transmission Cooler mounting location other than in front of radiator...
« Reply #10 on: April 27, 2014 - 12:17:13 AM »
Your memory serves you well, it is 1/8 NPT. I've orders some AN-6 fittings and some braided line, yet to order a cooler.
what about mounting it to the rear of the car? :dunno:, somewhere where stone damage is not going to cause grief, any ideas where or if its a good idea!
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #11 on: April 27, 2014 - 01:31:42 AM »
those stacked plate coolers are pretty tough, unlike an aluminum radiator.
2011 Kawasaki Z1000
