mainly from looking at the pics, I think.
Bars under 1.0 have an offset from one end to the other
Some bars that are larger don't have an offset.
My PST 1.03" bars do not, but, the pics of the Hotchkis 1.03" appear to have one to me.
I have to screw the adjusters in quite a bit to get the ride height I want. Trying to install them one "flat" installed was impossible with the ball joints connected....Just for the heck of it, I disconnected the upper and dropped the lower arm down so that I could get the bars in with that "one flat" difference. Then got a couple of guys to stand on the front end so I could reconnected the upper joint...placed the fender lip close to a foot above the tire
Changing it back to the correct position gave me a floor to fender lip distance of about 24.25" which is what I wanted...but the adjuster was turned within a 1/2" of max.
On the other hand, with a stiff bar like the 1.03", a little movement of the adjuster moves the car quite a bit once there has been some preload applied. I could get a lot more clearance with a little more adjustment.
