Author Topic: what plugs do you use  (Read 1146 times)
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« on: June 17, 2011 - 08:13:07 AM »
My small block has 13:1 compression-fairly large carb (850 )- and a fairly large cam  (284/292* -.533/.552 lift)-
itis mostly street driven to cruise nights and an occaisonal WOT run down the street. what plug (and heat range) and gap would you use
Re: what plugs do you use
« Reply #1 on: June 17, 2011 - 10:50:23 AM »
Well after proving on a dyno that the more you spend on a plug the more power you will LOSE , I lean towards the standard Champion RN12YC or RN14YC , use the colder plug , if you get any fouling move to the hotter plug , I would gap @ .040 if you have a high output coil , .035 if you have a std coil
 You could also use Autolite plugs , not sure of the heat range / #s for those
Offline OUTLAW
« Reply #2 on: June 17, 2011 - 12:41:49 PM »
ya I have a super coil and solid copper wires been running n14yc at .040 but the seenm to foul pretty easy - tried down jetting the primary to 64s but still loads easy -hate to go too lean on the primaries - I like Bosch plugs but around here all they carry are the platinums and 4 prong silvers and I hate both of them ,,,lol
guess I am gonna have to go to NGK (never liked them either ) or Autolites
Offline 7Dcuda
« Reply #3 on: June 17, 2011 - 01:53:03 PM »
I run the Copper Champion RJ12YC's gapped at .045 in my mild street build 440 with High Output Coil.  I've sampled many but have settled on this plug as working the best for me.
Offline TreeFrog
    • TreeFrog
« Reply #4 on: June 17, 2011 - 03:48:58 PM »
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
