Author Topic: Help! My motor is locked up!  (Read 34634 times)
Offline TinCuda
    • 'Cuda
« on: June 18, 2011 - 04:28:59 AM »
I don't guess anyone could help me out with a direction to look.   I have a 440 that seems to be locked up on me.   One day I went to start it and the starter just clicked.   The starter and solenoid are good.   Battery is good.   Good power to the starter when switch is turned.   A buddy of mine put a bar on the engine and he said the motor was locked up.  As I was not present,  I am not sure exactly was he did or what that means.   There is no water in the oil and the radiater is full of water.
The car was running fine the last time I drove it.
Can someone give me a direction I can look at with hand tools in my garage?   I am kind of cash poor right now and can't pay for an overhaul.
Thanks for any help.
« Last Edit: June 18, 2011 - 05:25:39 AM by TinCuda »
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Re: Help! My motor is locked up!
« Reply #1 on: June 18, 2011 - 08:29:58 AM »
Pull all the spark plugs and note any differences. Put a socket on the balancer bolt and try and turn it over. Are you SURE the starter is good? Double check to see if the starter gear is jammed up?
Offline Jesus H Chrysler
« Reply #2 on: June 18, 2011 - 09:35:05 AM »
By your description there could be many causes.  The most common no start I've run into is bad connections.  The battery will be fully charged, but all you get is a click.  Start by cleaning (or replacing if necessary) both battery terminals.  Double check the connections at the solenoid, starter, alternator and block (negative) to assure there is no "green nasty" crap built up.
Before you try to start it again, follow brads70's advice and pull the plugs.  Not knowing your friend, he may have mistaken what a "locked up" engine feels like.  With the plugs, accessories, fan and radiator in the way he may not have had enough leverage to be able to turn against the compression and resistance.  Pulling the plugs eliminates the compression and makes the engine easier to turn by hand.  Then do as suggested and get a socket and breaker bar for the crank bolt and turn clockwise.  It won't turn easy but should turn.  Good luck!
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #3 on: June 18, 2011 - 12:34:01 PM »
If it is a 4 spd you could try and roll start it. If cleaning your connections doesnt work, pull the starter and have it tested
72rtchallenger
what happens in the garage
stays in the garage
Offline mojavered
  • Someday!
« Reply #4 on: June 18, 2011 - 09:35:04 PM »
I thought my starter was good too, being brand new.  Just did not have the poop to do what it needed to.  It even tested fine.  Had a warranty, they replaced it.  New starter cured it!
Jason
« Reply #5 on: June 19, 2011 - 09:15:05 AM »
pull the plugs FIRST , if the engine flooded for some reason a cylinder could be full of fuel or coolant , forcing the engine to turn over will damage the engine , if you pull the plugs fluid can exit through the spark plug hole , the engine should rotate easily once the plugs are removed , watch for fluid , if there is a lot out of a spark plug hole either it flooded or youi have a coolant leak into that cylinder , possibly a badhead gasket .
Offline TreeFrog
    • TreeFrog
« Reply #6 on: June 20, 2011 - 12:06:30 PM »
Also ...
This may sound dumb, but when you turn the engine with a bar ... you need to take the belts off.
Might be surprised how many times we just forget to do the little things.
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline merlin969
  • North Carolina
« Reply #7 on: June 20, 2011 - 11:14:35 PM »
id pull the plugs next, then try and turn it over by hand again.  i would make sure the engine was ok before I looked into the electronics any more.
1972 Challenger, Nothing special. Just mine.
Offline Cooter
    • christinecarclub.com
« Reply #8 on: June 21, 2011 - 03:44:23 AM »
Not enough info.
Believe I'd get a second opinion...Running, then locked up sounds suspect to me...
« Last Edit: June 23, 2011 - 06:52:00 AM by Cooter »
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: June 21, 2011 - 09:53:04 AM »
I would start by making sure the starter gear is not jammed into the ring gear thereby locking the engine...
then follow Chryco's suggestions.
« Reply #10 on: June 21, 2011 - 05:08:48 PM »
Hey Tincuda how about an update?   :feedback:  :bigsmile:
Offline TinCuda
    • 'Cuda
« Reply #11 on: June 21, 2011 - 10:20:49 PM »
I have a guy coming by tomorrow afternoon to take a look at her.   I will let you know what we come up with.
Thanks for the input so far.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline TinCuda
    • 'Cuda
« Reply #12 on: June 23, 2011 - 01:51:34 AM »
Well I had a guy come by.   We pulled the spark plugs and there was no fluid in the cylinders.   He put a wrench on the engine and it would not turn either way.   Funny,  he said Yep it's locked up.
He is going to pick up the car and take a closer look at it in his shop.
I will let you guys know what we find out.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
  • 72 to 70 clone
    • cardomain
« Reply #13 on: June 23, 2011 - 06:46:12 AM »
I am betting the starter is locked up,,I have seen them lock in and not disengage and appear that the motor was locked up
72rtchallenger
stays in the garage
Offline sadil340
« Reply #14 on: June 23, 2011 - 06:59:47 AM »
 :popcorn:
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
