Author Topic: Help! My motor is locked up!  (Read 34642 times)
Offline TinCuda
    • 'Cuda
Re: Help! My motor is locked up!
« Reply #60 on: July 30, 2011 - 07:35:53 PM »
I am not looking for an exact horsepower figure.   I was wondering about a rough educated guess.
I am typing from my cell phone so sorry about not relisting the engine specks.   There should be enough information in past posts though.
Thanks
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
« Reply #61 on: July 31, 2011 - 12:39:50 AM »
if the machine work is done well & using a good set of matched parts you cold see over 600 HP & 700 Ft lb gross rated , or over 375 Hp & 440 Tq at the rear tires on a mustang dyno which read low
Offline TinCuda
    • 'Cuda
« Reply #62 on: August 13, 2011 - 03:25:37 PM »
Just one quick question.   I ordered the 440>>512 stroker kit from 440 Source with -27cc pistons.   Did I mess up?   Should have got the -17cc pistons?   Cast iron 906 heads and I want to run pump gas.   I want a reliable engine but not a powerless running car either.
Thanks
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #63 on: August 13, 2011 - 06:15:29 PM »
Call back & change the piston .the 5060 or better yet the 5070 would work best with an Iron 88 cc head
Offline TinCuda
    • 'Cuda
« Reply #64 on: August 13, 2011 - 07:17:55 PM »
How will that effect the balance of the kit if I change the pistons?
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #65 on: August 13, 2011 - 11:08:12 PM »
Ask 440 source what the piston weight is , Have you got the kit yet ?
Offline TinCuda
    • 'Cuda
« Reply #66 on: August 14, 2011 - 02:35:59 AM »
Yeah,  I already have the whole kit.   Crank, rods, and the pistons.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #67 on: August 14, 2011 - 03:40:13 AM »
you can easily match piston weight , just find the weight of the original pistons & make sure the new pistons weigh the same
Offline TinCuda
    • 'Cuda
« Reply #68 on: August 14, 2011 - 11:46:55 PM »
After giving it a lot more thought,  I am going to just stay with the pistons that I have.
The original idea of this build was to make an engine that would start every time and take on cruises.   Not drag race or "tear it up" on the street.   I think the lower compression will be just fine for that.   Using gas from any pump appeals to me more than going fast these days.   If I was to get fast, I can go in my 392 Challenger.   It would be a lot safer with its traction control and ABS anyway.
I guess I was just having a little buyers remorse.   I am over it now.
Thanks
« Last Edit: August 14, 2011 - 11:50:27 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #69 on: August 15, 2011 - 12:10:49 PM »
I disagree , the higher compression with better quench is a better combo to kill detonation & work better even on a street engine
Offline TinCuda
    • 'Cuda
« Reply #70 on: August 16, 2011 - 02:23:56 PM »
I was ordering the kit based on what my machinist told me to get.   I know that a 906 head should have a volume right around 88cc.  I was thinking my machinist said my heads had been shaved at some point in the past.   Somewhere in this whole process I got the idea that my heads cc'd out to 84cc.  I will have to double check when I get back to the states in a couple of days.
Sorry about spelling and grammar.   I am using my cell phone.
My machinist knows a lot more about this than me and I am sure I am missing something that I should be telling you.
I know that this is the third time this block has been rebuilt and my machine guy had me get 0.55 over on the bore.
If you have any questions that will help you help me,  please ask.
Thanks again.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #71 on: August 17, 2011 - 09:36:07 AM »
well the Most important aspect is quench , I have seen low 9:1 compression engine detonate hard all due to the relief in the 906 heads / open chamber , you need to get the piston into the .040 - .060 range with the head to kill detonation , so more compression is better as long as you have good quench . Living at high altitude I have been able to run as high as 10.6:1 on pump gas with quench & no detonation
Offline TinCuda
    • 'Cuda
« Reply #72 on: August 17, 2011 - 10:57:24 PM »
Thank you very much for all the help so far.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #73 on: August 18, 2011 - 02:04:34 AM »
No Problem
 Glad to help
Offline TinCuda
    • 'Cuda
« Reply #74 on: September 24, 2011 - 09:16:30 PM »
Ok, more problems.
I got the hemi style 6 quart oil pan from 440 source and the oil pick up tube that fits that pan in 1/2 inch.   I have resized the threaded myself into a 1/2 inch commitment.
Problem is, it won't work with the stroker windage tray also from 440 source.
I could go with the 7 quart oil pan and tube but I already have the 6 quart pan.
Or I could go with out the windage tray.   I really want to use a windage tray.
Any ideas?
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
