Author Topic: Will this steering coupler work?  (Read 588 times)
Offline wart1de
    • Vivah
« on: June 18, 2011 - 05:22:17 AM »
Hey all,
I picked up this 2nd hand steering coupler from ebay, it was meant to suit a Cuda with power steering however when it arrived it turned out to be a fair bit shorter.  The area with the actual splines appears to be the same length and in the same position so I dare say it will connect to the steering box ok. Where it is shorter ( approx 3/4 " ) is the shell(lack of a better word) that goes around the steering column. Will this be a problem?
Also, there is a pin missing from the new one. Can anyone tell me what this pin is for? I could probably put the pin from the old one into the new one if needed.
Thanks!
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Re: Will this steering coupler work?
« Reply #1 on: June 18, 2011 - 08:21:39 AM »
That pin keeps the coupler from coming off the shaft when assembled. If you get a rebuild kit that pin comes with it. It's cheap, like $15 I think? Weather it will work of not ( lenght ) I don't know? I would guess yes as the main shaft does pull out some.
« Reply #2 on: June 18, 2011 - 09:27:36 AM »
justinstall al new kit usingthe old coupler , the couple is rarely damaged
Offline wart1de
    • Vivah
« Reply #3 on: June 18, 2011 - 09:53:41 AM »
The splines in the old coupler are badly worn. Luckily the guy doing the panel work noticed when he pulled the steering out to paint the engine bay. He thinks the wear was caused by someone not fitting it properly.
1973 Plymouth 'Cuda
