Author Topic: tpms in the tires  (Read 2349 times)
Offline hpe600rt
  • how sweet it is
tpms in the tires
« on: June 18, 2011 - 10:31:04 AM »
what happens  when you dont put in the tpms in the rims i heard just a light goes on can you shut it off any info on this would be great thanks
Re: tpms in the tires
« Reply #1 on: June 18, 2011 - 05:20:42 PM »
A light comes on, but I don't know of a way to turn it off.
Offline footin70rt
« Reply #2 on: June 18, 2011 - 08:03:23 PM »
As long as the TPMS sees a fault the light will remain on. Unfortunately there is no way to shut the light off permanently. Then again
you can always take the bulb out.   :stirpot:
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline hpe600rt
  • how sweet it is
« Reply #3 on: June 18, 2011 - 08:04:44 PM »
well i paid 100 for all 4  rubber ones and they dont fit the ccws so should i go with the metal tpms just want to make shure they will fit this time around.
Offline hpe600rt
  • how sweet it is
« Reply #4 on: June 18, 2011 - 08:08:51 PM »
whitch bulb would it be to take out that seems to end it thier as i dont need them anyway mine is not lit up yet so i dont know the bulb to pull,the car is still on jack stands in the frount.
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #5 on: June 18, 2011 - 11:26:56 PM »
Just swap your sensors from your old wheels, you cant take the bulb out of the cluster.
2013 Tige' RZR 343hp
Offline hpe600rt
  • how sweet it is
« Reply #6 on: June 19, 2011 - 04:11:48 AM »
that wount work i bought new one from ebay the same one for the rt 20 but they dont fit the ccws,mabee they use srt8 ones they might be just a tad differnt
« Reply #7 on: June 19, 2011 - 09:03:45 AM »
the best fix I know of for this is to build a small tube with a valve stem using plumbing PVC tube , throw in all 4 senosr & inflat to 40 psi & put it into the trunk
Offline hpe600rt
  • how sweet it is
« Reply #8 on: June 19, 2011 - 10:13:38 AM »
does that work ,i wouldnt know how to do that
« Reply #9 on: June 19, 2011 - 11:57:28 AM »
yes it works , just take a piece of black or white plumbing pvc tube ,  ,drill a hole into the cap & install a valve stem , glue or thread the caps on both ends with the sensors inside , inflate to 40 psi , toss it into the trunk & forget about it !!
Offline hpe600rt
  • how sweet it is
« Reply #10 on: June 19, 2011 - 12:40:18 PM »
ok ill try that thanks,is that what you did
« Reply #11 on: June 19, 2011 - 01:18:57 PM »
yup  :2thumbs:
Offline hpe600rt
  • how sweet it is
« Reply #12 on: June 19, 2011 - 04:59:25 PM »
do you have a pic of how you did it just to give me a better idea of how to
Offline hpe600rt
  • how sweet it is
« Reply #13 on: June 20, 2011 - 07:11:38 PM »
i take it up to discount tire and they put them right in they said the guy who mounted the tire should have lubed them up.what a dumb ass so now they are in thanks guys
Offline MJS73
    • Mike's 1973 Challenger
« Reply #14 on: June 23, 2011 - 02:32:18 PM »
That's genius.
www.mikes73.com
