Author Topic: 3-point rear belts  (Read 11754 times)
Offline shawge
  • Zoiks!!
Re: 3-point rear belts
« Reply #15 on: October 04, 2013 - 02:40:54 PM »
Another site that shows a retrofit in a Mustang.  This one has the retractor anchored to the wheel well and goes through the package tray.
http://www.472ci-67mustang.com/Seat_Belt_Pages/67shoulderbelts-large.htm
Looks doable in a E-body but I'd probably want a beefier belt guide on the package tray.
- Jerry
Offline Katfish
  • 70 Challenger
« Reply #16 on: October 04, 2013 - 04:53:04 PM »
Looks nice, I wish these guys would have better details on the donor parts used.
Offline shawge
  • Zoiks!!
« Reply #17 on: October 04, 2013 - 05:39:03 PM »
The Mustang used belts and retractors from a 89/90 Hyundai Excel.
- Jerry
Offline AU6pack
« Reply #18 on: October 20, 2013 - 07:39:39 AM »
I just bought a pair of above mount ones http://www.hemiperformance.com.au/store2/p_612_Rear-Retractable-Seat-Belt-top-of-parcel-shelf with a cover to sit on top of the parcel shelf. These will sit on the far left and right sides, not the center as I have seen some do.
I bought 2 1970 lap belts from year one which i am using as donors for the tongue and buckle on the new retractables, so they looks as original as possible. It should be a pretty easy install.
I would post some pics but I just boxed them all to go to a seat belt vendor to cut an resow the belts and buckles. I will post pics when they come back.
The under shelf ones look great but its a much bigger project than I want and I think these will look fine, and still be on the far left and right of the seats which is what I'm after.
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline dutch
« Reply #19 on: October 20, 2013 - 08:50:44 AM »
so, how do you reinforce underneath.  Just a bolt through the sheetmetal won`t do  :grinno:
*** Bart ***
Offline shawge
  • Zoiks!!
« Reply #20 on: October 20, 2013 - 12:32:16 PM »
The kit AU6pack got comes with a reinforcement plate - the grey rectangular piece on the far right.
- Jerry
Offline AU6pack
« Reply #21 on: October 21, 2013 - 04:14:59 AM »
I'm going to put a 3" x 3" plate on the top and bottom of the sill, as the retractor will sit right near where the sheet metal has some holes punched for what i guess is convertible top brackets.
Craig
Offline AU6pack
« Reply #22 on: October 21, 2013 - 05:24:55 AM »
Here are the new belts and the donor ones from Year one.
Craig
Offline walkAbout
« Reply #23 on: November 04, 2013 - 05:37:35 PM »
Hi Jerry,
what do you mean exactly? Sorry, i can't follow, where the kit ^^ belongs to. I also need the reinforcement plates and appreciate any input how to build them (let them build).
CU
walkAbout
Offline shawge
  • Zoiks!!
« Reply #24 on: November 04, 2013 - 06:47:07 PM »
Hi Jerry,
CU
walkAbout
This is the kit AU6pack bought, I've circled the reinforcement plate.  I've seen examples of plates where the nut is welded to the plate and, in this case, where the nut is not welded.
[/URL]
Something like this from the site you mentioned previously
http://www.stevens-shop.de/shop/Seat-Belts/additional-fittings/THREADED-PLATES-pair-for-seat-belts::1379.html?XTCsid=b99659e044d73fe3d180cb4ada1fe965
Edit: fixed typos
- Jerry
Offline Tonker1
« Reply #25 on: November 05, 2013 - 05:36:45 AM »
The rear retractor install on the mustang is very clean, you would hardly know they are there when looking into the boot. I'll be interested to see where this ends up, as I would like to do something similar in the next few months.
Offline walkAbout
« Reply #26 on: November 05, 2013 - 03:34:00 PM »
Many thanks, very simple...
Yes, saw this, but the Challenger has a square hole and I think there is not much to reinforce, more to close the hole (didn't measure it till now). I will let somebody make the original reinforcement plate like in the engineering illustration if it is payable. Don't play with safety. I think the engineers back in the 70s made it right already.
CU
walkAbout
Edited a typo ^^
« Last Edit: May 27, 2014 - 04:25:47 PM by walkAbout »
Offline walkAbout
« Reply #27 on: May 27, 2014 - 04:23:22 PM »
I will let somebody make the original reinforcement plate like in the engineering illustration....
Yehaa. Done. Will pick up the 2 assies on thursday and let you know. Done a little bit different, but stronger. We will see. I'll keep you updated.
CU
walkAbout
Offline shawge
  • Zoiks!!
« Reply #28 on: May 27, 2014 - 05:06:19 PM »
 :popcorn:
- Jerry
Offline walkAbout
« Reply #29 on: May 29, 2014 - 04:48:11 PM »
Keep it simple.... One strong plate of metal and the square raising one top. The raising bit higher on the outside and lower on the inside and to fit to the square whole, that is already in place. Will try it in the car the next days and have to drill the holes and thread to mount it from the top through the holes next to the square hole.
CU
walkAbout
