I'm struggling with getting my water temp gauge working. Here's what ive done so far, pulled off the sending unit wire and grounded it and the gauge pings out just fine as it should so the gauge and wire are good at that point, you'd assume just a bad sensor, so i picked up a new one and installed it without any tape to ensure it gets a good ground from the intake, when i took out old sensor, coolant pored out so good water flow there, but still not a sign of life from the gauge.. any other suggestions would be helpful.
thanks,
tim
