Author Topic: Dyno finally done :)  (Read 2862 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
« on: June 20, 2011 - 02:51:49 AM »
Put my chall on a chassis dyno today  :ylsuper: :bananasmi
440 30" over
Eddy heads 84cc
Hyd comp cam 545 lift 110 lobe sep 285 dur intake and 297 dur exhaust
Cast crank all standard bottom end.
Torquer 2 manifold
850 demon carb
Manual trans
3:73 tru trac 8 3/4
1" 7/8 primarys but ****ty 2.5" from collectors back.
Im pretty happy with the outcome :droolingbounce:
I had a 5800 rpm chip in the box but im going to run a 6200 chip as the power kept building and building.....
Offline cudachall74
Re: Dyno finally done :)
« Reply #1 on: June 20, 2011 - 04:05:37 AM »
 :2thumbs:nice numbers there old fella,i think you owe the bloke that sold you that monster a beer or 50 :drunk:
74 barracuda
74 challenger
Offline TreeFrog
    • TreeFrog
« Reply #2 on: June 20, 2011 - 11:27:02 AM »
cool
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: June 20, 2011 - 09:38:48 PM »
Very good numbers.   :2thumbs:
With a 30% drop in HP to the rear wheels you have about 450 hp to the fly wheel.
Your engine set up is close to mine, so it's god to see what numbers you ran.
What were the torque numbers?
Offline punisher72
« Reply #4 on: June 22, 2011 - 06:53:04 AM »
Not 100% sure but I remember  it being 367 at around 4200 rpm.... I will find out for sure soon enough.  :2thumbs:
Offline shadango
« Reply #5 on: June 22, 2011 - 07:15:47 AM »
Looking at your chart and such, I started wondering (cause I really do not know).....does rear tire size come into play at all when on the dyno?
 :clueless:
I am afraid to have my little 318 dyno'd cause I would probably be disappointed and then would start looking to upgrade....LOL
Offline 67vertman
« Reply #6 on: June 22, 2011 - 09:18:53 PM »
My 440 should be done in the next two weeks, and we are going to dyno it then.. I can't wait to see the numbers.  I am shooting for 500 at the fly wheel and 550 ft lbs of torque.
« Reply #7 on: June 22, 2011 - 10:03:02 PM »
And I hope to go for a ride in that bad boy.  I will be in yer area pretty soon
Offline mopar12372
    • mopartech
« Reply #8 on: June 22, 2011 - 10:23:00 PM »
wow those are some good #s for a stock btoom end 75 in the hole !!! impressed :2thumbs:
RESTO PICTURES
Offline punisher72
« Reply #9 on: June 23, 2011 - 01:18:10 AM »
Thanx guys!!!! Id like some more HP but dont want to spend a fortune on a big rebuild.....
Anybody got any ideas?????
The carby was on the limit of being too big but will be perfect when i up the anti a bit  :grinyes:
Shadango,Im not real good with all the technical stuff but i wouldnt reckon the wheel size would make a difference??
67vertman,what exhaust are you running and what are your engine specs??
Offline 67vertman
« Reply #10 on: June 24, 2011 - 12:39:16 AM »
Sweet, I will get to spend some time with you again.   :bananasmi
Offline mopar12372
    • mopartech
« Reply #11 on: June 24, 2011 - 01:01:22 PM »
well the performer rpm would help you alot with your setup . replace the pistions (raise the compression) youll see even more improvement  . i like at least 11 to 1 for aluminum heads . then 500 the rear wheels with some minorto myour setup  changes shouldnt be a problem.
RESTO PICTURES
Offline aris_unlimited
  • Project in full swing
« Reply #12 on: June 24, 2011 - 02:39:28 PM »
 :clueless:
I don't think diameter would really have much to do with it. But the weight of the wheel/tire would definitely effect it. The more rotational mass you have be it transmission gears/drive shaft/rear end/ tires will effect how much hp/tq is allowed to go from the motor down to the dyno machine. That is why you have a loss of power, and why racers are constantly looking for lightweight, strong wheels.
Cuda is gone :(
74 satellite, daily driver/project now
Offline lemming303
  • San Antonio, TX
« Reply #13 on: June 24, 2011 - 07:10:46 PM »
Nice numbers! I can't wait to start putting my motor together
Kevin
73 Challenger Rallye - first project
Offline 67vertman
« Reply #14 on: June 24, 2011 - 08:41:13 PM »
 :woohoo: My engine builder called today!  :woohoo:
and said, the bottom ends done and the motor should be completed by Thursday, if the head gasket show up on time. He will break it in on Thursday and do a dyno pull on Friday.
 :jumping:
Now starts the longest seven days of my life.  :walkaway:  :woo:
