Author Topic: 340 / 360 fuel line pic request  (Read 881 times)
Offline CUDA JAS
  • vroooooom!
« on: June 20, 2011 - 12:38:18 PM »
Does anyone have pics of the fuel line from the pump to the carb (focusing on the pump side) on a small block.
I just installed a fuel pump on my 360 and want to bend up some lines for it and wanted to get a visual of how they went.
Thanks,
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: 340 / 360 fuel line pic request
« Reply #1 on: June 20, 2011 - 01:24:43 PM »
There are pics in my resto thread, page 15.  You'll see where Rod took off the glass filter and bent the new fuel lines and put on the new filter. Hope it helps. http://www.cuda-challenger.com/cc/index.php?topic=72522.210
Offline femtnmax
« Reply #2 on: June 20, 2011 - 08:47:09 PM »
Here is my setup for thermoquad carb.  Fuel line is 5/16 inch brake line tubing bent by hand using cheap tubing bender.
The fuel filter is back by the gas tank between tank and electric fuel pump.  The electric pump is behind the rear seat back on LH side just above the factory mount location for exhaust hanger.  The electric pump is to prime the system, otherwise fuel is drawn and pumped by the mechanical pump with elec pump as a back up.
« Last Edit: June 20, 2011 - 08:51:26 PM by femtnmax »
Phil
