Author Topic: Heat Control Valve - What does it do?  (Read 635 times)
Offline jforest1
« on: June 23, 2011 - 01:54:45 PM »
I not-so-recently discovered the heat control valve on my factory exhaust manifold.  What exactly is its purpose?  Can it be removed permanently and if so what are the tradeoffs?
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: Heat Control Valve - What does it do?
« Reply #1 on: June 23, 2011 - 02:50:57 PM »
When the engine is cold, the valve is closed and restricts exhaust flow.  That restriction forces exhaust gasses to pass through the intake manifolds exhaust crossover port over to the other side.  This is done to help bring the engine up to opperating temperature faster.
There is a metal spring that loses tension when it is heated up.  That allows the valve to open when the engine is up to temp.  If you have the exhaust crossover port blocked off, there is no reason for the heat riser.  Most original heat risers aren't in the best condition after all these years and no longer work properly.  You can buy a kit to rebuild them but most people just weld the flapper in the open possition and call it done.  If you choose to do that, the car will take longer to get up to operating tempurature and may run rough on startup.
Offline jforest1
« Reply #2 on: June 23, 2011 - 04:57:12 PM »
NOW IT ALL MAKES SENSE!
http://www.cuda-challenger.com/cc/index.php?topic=75341
!!!!  :cheers: :cheers: :cheers:
Thanks!!!
JF
