Author Topic: Switch located on trans. what wires go there?  (Read 1485 times)
Offline cmesa
« on: June 24, 2011 - 06:57:50 AM »
Thanks to help from a previous post I found the swtich located on the trans. I ran a wire from the dash light that should light up when I put the car in reverse (thru the bulkhead). I thought I could attach it to the switch, but the switch has 2 prongs. So my question is what wire go there?
Thanks to all for read.
Offline Strawdawg
    • Vortex Buicks
Re: Switch located on trans. what wires go there?
« Reply #1 on: June 24, 2011 - 10:41:57 AM »
On a manual tranny car, the two pins are for the back up lights
Offline cmesa
« Reply #2 on: June 24, 2011 - 10:49:23 AM »
Thanks, so my light on the dash that should light up when I put the car in reverse has 1 wire where does that go to?
Thanks again.
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: June 24, 2011 - 12:34:45 PM »
I am not familiar with that light, but I will look at the wiring diagrams again and see if I can find it...did not see it mentioned before...I looked at a '70 manual and a '73 manual...hard to find things sometimes due to the amount caramed on a small page
Offline 7Dcuda
« Reply #4 on: June 24, 2011 - 12:40:46 PM »
Thanks again.
12V goes to one terminal on the switch straight from the fuse block.....the other terminal has the wire that goes back to the reverse lights.
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: June 24, 2011 - 01:26:14 PM »
Here is a link showing the hole in the firewall where the single wire from the light goes thru to under the hood  http://www.cuda-challenger.com/cc/index.php?topic=72062.0
It appears that it goes from the dash, thru the hole in the firewall to the black/white wire coming from the switch on the tranny that comes back from the switch to terminal 7 on the bulkhead connector.  On the inside of the car 7 goes to the connector that connects the rear wiring harness to the light switch down by your left foot by the kick panel.
If I were doing it, and not doing a resto, I would simply connect it inside the car to the wire going to the reverse lights but, I like to do things the easiest way.
All this light does is pick up power going to the reverse lights when the the reverse lights come on...it is a single wire as the other side of the bulb grounds to the dash.   On the inside of the car, I believe it is a white wire with a black tracer that goes to terminal 6 of the rear harness connector.
« Last Edit: June 24, 2011 - 01:39:03 PM by Strawdawg »
Offline cmesa
« Reply #6 on: June 24, 2011 - 02:39:32 PM »
THANKS FOR THE HELP.
HAVE A GOOD WEEKEND!!!
