Week 49:
The brake lines and new master showed up I took some side by side images of the two
Brake lines
Master Cylinder
I spent the majority of the week removing the old lines and installing the new ones. It was a very dirty job and a lot more work than I expected, but I finally managed to install all the lines. I thought for sure the long body line would be a the most difficult, but it turned out the front passenger side was the most trouble. The hard line was a pain to install due to the clearances with with booster/firewall/engine. And the threads on the caliper that the soft line connects to needed to be cleaned up.
I decided against swapping the prop valve, I have heard aftermarket ones had issues. So once it was free from the lines, I pulled the old one off the car:
I soaked it in evapo rust, brushed it, soaked it again, and then soaked it in mineral spirits to flush it all out:
Pretty happy with the way it turned out, not true original condition but a pretty good match for the new master.
I also did some work on the replacement bumper filler I have had sitting in my basement for a few months. It's awfully time consuming to remove the existing paint but I've got the process down now:
It gives me something to work on when I don't feel like crawling under the car or when I am waiting for parts.
Next week I hope to bleed and install the master and then bleed all the brakes. Who knows I might even get to drive the thing
