I love that stance with those nice fat tires up in those wheel wells!!
Thanks for the compliment.
I worked more on the carb/choke over the last few days. After installing it, I started the engine cold and it ran for 15-20 seconds and then died. Started it again, it lasted a bit longer, 3rd time and it ran until I turned if off. I did some looking and determined the fast idle wasn't set correctly. The kit included a new fast idle arm/screw so the initial install was just a guess. Turns out I had it installed in such a way that the fast idle was lower than the curb idle, so it would just curb idle. Unfortunately the new choke set up blocks easy access to the fast idle screw so I had to pull the carb off, readjust it and put it back on the car. This time I made sure the fast idle would engage.
The next day the car fired right up and held, running in fast idle until the choke was off and then switching to curb idle. I can't express how nice it is to go out, get in the car, turn the key and it just starts and runs. It's been a long road to get there swapping the plugs, rebuilding the carb, setting the floats, idle mix, curb idle and then setting the timing. A lot of which I probably would have never figured out without help from the people and posts on this board.
It was also great to remove that ugly manual choke knob/cable
