I found a replacement rear harness for the challenger. It didn't show up until Saturday, so I didn't get around to installing it. However I took the time to test the wires and they all seem to be correct. I'll have to do a comparison between my existing harness to get the exact results, I suspect some green death is the cause of issues with my reverse lights.
Next up my lap belt loops showed up. I took a few minutes and installed them. Really they probably don't do much, but after the trouble finding them I am just glad to have them installed.
A while ago while working under the hood, I noticed some cracks in the extension shield
I decided to pull it and that's where the trouble began. Removing the bolts was no problem, but I quickly discovered that to pull it, I'd need to remove the air shield. Every bolt on this thing was rusted solid. I sprayed it multiple times but still ended up breaking 3 of the 5 bolts. Fortunately they should be easy to remove. Once I got the part out I discovered that the driver's side was completely broken off.
I also discovered a tag on the bottom which is in amazingly good shape considering where that part sits:
And finally while I was under the car messing with the air shield....I noticed the parking lights didn't look right.
My first thought was the wrong part was used....but then I checked the other side and realized it was the same...and then it hit me....they were installed on the wrong sides. 4 screws later and everything was back to normal.
