Author Topic: tune-up instructions decal  (Read 1662 times)
Offline thedeputy
« on: June 28, 2011 - 10:45:34 AM »
Hi Guys.
I'm still in the process of restoring my 1970 dodge challenger deputy, and I've arrived at the detailing part of the car.
When looking through some old pics, I noticed a sticker that was on the passenger side inner fender. Unfortunately i don't have clear pics of the decal, because There weren't any digital camera's when I was disassembling my ride.
I do however copied the text on the sticker before I had everything blasted. It says the following:
Tune-up instructions
This engine is equipped with a "kar-kit" emission control system
the distributor vacuum spark advance mechanisme must remain De-activated
according to special instructions in owners manual.  engine timing and
carburator adjustment must be set according to the following "kar-kit"
specifications see manual in glove compartment for detailed procedures
1966-1970 vehicles
timing              MFG. specs                                              kar kit specs
                  1' BTC or more retarded          -                  same as MFG. specs
                  more than 7 1/2' BTC              -                   set at 1/2 of MFG. spec
                  All other settings                     -                   set at 1' BTC
carburator adjust idle speed and mixture to MFG-spec. If idle mixture is not specified
adjust to lean best idle
1955-1965 vehicles
timing         Set timing according to manufacturer's specifications
carurator    Adjust idle speed to 600 RPM in drive for automatic transmissions
                  and 700 rpm in neutral for manual transmissions
                  Adjust idle mixture to 1,5% co- or 14:1 AFR. if not possible
Check cooling system for leaks. Defective cap and plugging every 120000 miles
Air quality products inc. 1976   AQP 229 11/76           patent pending
This was the full text on the sticker. If anyone has some knowledge on this sticker please feel free to share it with me.
Thanks,
Antoon
Re: tune-up instructions decal
« Reply #1 on: June 28, 2011 - 11:04:59 AM »
Performance Car Graphics sells a lot of stickers like that.  Check out their site and see if they make that one.  They have pictures of all the stickers they sell.  Also, I know ECS Automotive has been coming out with a lot of stickers.  They sell kits with all the sticker for the car in it.  Check them out too.
Offline thedeputy
« Reply #2 on: June 30, 2011 - 03:51:51 PM »
Thanks.
I allready looked at the ECS site, since they've helped me in the past with the VIN decal that goes in the door. But I didn't find any info on this particular sticker. I mailed PCG for some info, so maybe I'll get lucky.
It seems though, that it's a sticker from some system, not made by Chrysler, to enhance the emissions of the engine. Does anybody have an idea what this Kar Kit system could be?
Antoon
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: July 01, 2011 - 01:46:07 PM »
The kar kit is an aftermarket smog control device - it wasn't stock. They were installed when you had your car smogged. Personally, I wouldn't put it back on unless you are going for a "period" restoration - plus it makes your car drive horribly since you retard the inital timing and disable the vacuum advance.
Offline thedeputy
« Reply #4 on: July 06, 2011 - 04:21:19 PM »
Ok thanks for the info.
I wasn't planning on installing this Kar-kit device. It wasn't on th ecar when I bought it, just the decal, and I wondered what it meant.
Thanks,
Antoon
