Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
over charging.. what now?
« previous
next »
Print
Pages: [
1
Author
Topic: over charging.. what now? (Read 689 times)
Talkwrench
Perth, Western Australia
Jr. Member
on:
June 29, 2011 - 07:53:29 AM »
My battery went cactus over the weekend and I had to charge to get it going, I thought I would check the voltage at the battery and it was charging at 15 volts..I take it that its over charging, Sooo whats the deal with the regulator, what where when and how??
Logged
"Came too close to dying to stop living now!"
nqkjw
Full Member
Re: over charging.. what now?
Reply #1 on:
June 29, 2011 - 08:29:50 AM »
15 is a little high.
Should be between 13.8 and 14.4
Just change out the reg.
Logged
Burnouts are cool but Traction is the Action
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
June 29, 2011 - 08:35:26 PM »
it could be a bad diaode in the alt also , the reg is on the firewall & is approx $15
Logged
Strawdawg
Resident
Reply #3 on:
June 29, 2011 - 09:10:41 PM »
could it be that it is charging that high because your battery has a bad cell?
Logged
Steve
www.vortexbuicks-etc.com
Moparal
Permanent Resident
Reply #4 on:
June 29, 2011 - 10:20:42 PM »
also, make sure your regulator has a good ground or it will over charge
Logged
Talkwrench
Jr. Member
Reply #5 on:
June 30, 2011 - 02:57:45 AM »
Thanks guys, I'll check the ground, then battery , then reg if needed.. and pray its not a diode..
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
