Author Topic: HID headlight housings  (Read 5446 times)
Offline joef89
  • 74 Challenger RT
« on: July 01, 2011 - 02:07:48 AM »
Hello i have a 74 challenger and i was wondering if anyone knew of a headlight housing kit that i would be able to install HID bulbs in? my current headlights just arent bright enough to see down the road.
Re: HID headlight housings
« Reply #1 on: July 01, 2011 - 08:49:22 AM »
I have yet to see a kit for HID(looks like one bulb w/housing run about $500ea  :scared: ) but there are plenty of 5.75" halogen conversion housings on the market, once you find the housings upgrading them does not seem to be an issue.
You may find the halogens sufficient.
Some good info here http://www.cuda-challenger.com/cc/index.php?topic=67883.msg696879#msg696879
« Reply #2 on: July 01, 2011 - 10:06:31 AM »
Just use a Bosch type H1 or H4 housing & install the HID bulbs into those
Offline joef89
  • 74 Challenger RT
« Reply #3 on: July 01, 2011 - 10:42:35 AM »
Thank you for all the help. i have read that thread before. now i just have to find a housing unit.
« Reply #4 on: July 01, 2011 - 07:36:11 PM »
Hey welcome to C-C.C   Your '74 looks sharp  :thumbsup: . What color is that?
One member said he used these housings http://www.slickcar.com/details/1028-h4-headlight-conversion.asp#.Tg5aOWHyA1c
Offline Katfish
  • 70 Challenger
« Reply #5 on: July 01, 2011 - 08:00:57 PM »
Might want to read this, sometimes our dim headlights are caused by the wiring.
http://www.madelectrical.com/electricaltech/brighter-headlights.shtml
Offline joef89
  • 74 Challenger RT
« Reply #6 on: July 01, 2011 - 08:34:32 PM »
Thanks for the help with the housings. and the color is 01' Viper Race yellow
Offline ShelbyDogg
« Reply #7 on: July 05, 2011 - 12:55:57 AM »
I used (2) H4 conversion headlights from Pilot, on my hardtop. With headlight relays they are bright enough and you didn't have to spend $500 for HID lights. I used 4 similar ones on my convertible.
http://www.jcwhitney.com/seal-beam-halogen-headlamp-conversion-kit/p2003804.jcwx?filterid=c2824d406y1971j1
Offline rallye73
  • Model cars for the big boys!!
« Reply #8 on: July 05, 2011 - 02:20:41 PM »
You might try DDM Tuning. That's where I bought my HID's for my Neon. They carry alot of different type kits. The prices are real good and the product is top notch.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: July 05, 2011 - 03:04:39 PM »
Are you using h4/9003 bulbs in all four, or single filament bulbs in the two "high beams"?
Offline ShelbyDogg
« Reply #10 on: July 05, 2011 - 04:37:26 PM »
I use (4) H4 dual filament bulbs but only use the 2 outer pins in the high beams. I cant remember if I just turned the plug upside down or bent the middle terminal out of the way. Either way, you'll have 2 spare low beam bulbs if needed.
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: July 05, 2011 - 05:47:41 PM »
that would certainly be an easy way to do it...wondering what would happen if you used two relays...one to power four low beams and one to power four high beams....
« Reply #12 on: July 05, 2011 - 07:03:52 PM »
I see there are multiple selections of bulbs Halogen H4, 90/130 Watts, 55/100 Watts, 55/60 Watts
  also Xenon H4,90/130 Watts, 80/100, 55/60 Watts. All $24 or less a pair at Summitt Racing
What would be the most appropriate?  :clueless:
Offline ShelbyDogg
« Reply #13 on: July 05, 2011 - 08:32:46 PM »
I think 55w is the max most allow for street use. As for the high beams put in as big as you want. You have to low beam oncoming traffic anyway.
 Painless does sell a relay kit that leaves the low beams on when the highs are on so you could set it up like that too.
Offline Strawdawg
    • Vortex Buicks
« Reply #14 on: July 05, 2011 - 08:35:12 PM »
with a plastic housing, one has to be careful to not use a bulb that generates so much heat that it melts the housing.
There also used to be some legality as I recall against using bulbs around 60 or 65 watts...not sure if that still stands
One also has to be careful not to overload the capability of the alternator.   four or five amps is about what each element draws...for a 60 watt filament
