Brakes with never ending story.....
Author Topic: Brakes with never ending story.....  (Read 4018 times)
Offline spamtank
Re: Brakes with never ending story.....
« Reply #15 on: July 09, 2011 - 09:00:21 PM »
Now it goes on...
I took apart the new distribution block on the lover end.
The valve doesn’t look really nice. The corners from the valve are just a little bit cant. :poopoke:
The valve it’s heavy and made from brass.
Who did you get the new distribution block from?  I'm thinking about ordering parts from "In-Line Tube."  Are there any other suppliers?  Has "In-line Tube" provided acceptable parts?
Looks like I might be going down the same road as you with the rebuild.
Hope the road test was successful.  :popcorn:  :burnout:
Thanks,
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline 4yuckfous
« Reply #16 on: August 04, 2015 - 09:45:45 AM »
Finally
After 4 years of trubble and no brake power if you press quickly, I decided to put in a new Wilwood proportional valve.
The brakes before work verry well , if you steped on it slow, but no reaction if you quickly brake.
I changed 2 times the proportional valve in "original" style, probably both were made at the same factory, the same reproduction-****....
One I bought at Yearone, one at Inline-Tube.
Both had the same failure.... if you step quick on the brakes, the brakes didn't release for a while.
If you steped quick on the brake pedal, nearly no brake effect.
If you steped slow on the prake pedal, you almost flown out the window.
I wanted to let you know what's happening now.
Fix and bend new brake lines around the Wilwood proportioning valve and........
it works perfect......
Thank you for your feedbacks and support :wave:
The streets don't get wider, if you drive slower !
