Author Topic: Battery Slowly Draining Help  (Read 996 times)
Offline 318Sebring
« on: July 02, 2011 - 08:51:05 AM »
Hello
My battery is slowly draining on my 72 318 Sebring.
The battery is 9 months old.
When fully charged  ( Charged with a  Battery charger ) it reads  12.4 V  according to my multimeter Tested at the poles.
When the engine in running ( Idle ) it reads 12.2 V at the poles and 12.1 V at the connectors
After driving approx 100 miles the battery reads 12.2 V and 12.1 V at idle. again 12.1 V at the connectors.
Eventually the car is hard to start. You know what happens next.  :stomp:
Altinator ???
Any suggestions before I replace the altinator ?
Thanks in advance
Fred..
Offline Strawdawg
    • Vortex Buicks
Re: Battery Slowly Draining Help
« Reply #1 on: July 02, 2011 - 09:33:11 AM »
Well, the battery is obviously not being charged by the alternator so you have to determine if the alternator is bad, or the regulator is bad.
You might read this thread if you have not   http://www.cuda-challenger.com/cc/index.php?topic=77684.0
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: July 02, 2011 - 10:28:43 AM »
 :iagree: it should be 13 to 14 v when idling ,,check to see if your getting better voltage at the alternator post
72rtchallenger
what happens in the garage
stays in the garage
« Reply #3 on: July 02, 2011 - 10:41:31 AM »
you can have the Alternator tested , the regulator is on the firewall has a triangular plug with two w ires running to it the reg is only $15 to replace
Offline 318Sebring
« Reply #4 on: July 02, 2011 - 03:13:56 PM »
I just had the Alternator tested .
Its going South.
As per Chryco Psycho, for $ 15.00 with will also replace my 40 year old regulator
Thanks for the help.
Fred..
Offline ShelbyDogg
« Reply #5 on: July 05, 2011 - 12:42:06 AM »
Its going South.
Fred..
Save that 40 year old regulator. It might be better than the new one you're buying. Always keep a spare in the glove compartment along with a balast resistor.
