Author Topic: How to do with front floorcorners?  (Read 745 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: July 02, 2011 - 03:04:45 PM »
Got the floor out but at the front corners it's not possible to reach with a drillingmachine to drill out
the spotwelds, how to come around that? Weld the new floor over the old seem or try to remove the old floorpieces somehow?
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline dutch
Re: How to do with front floorcorners?
« Reply #1 on: July 02, 2011 - 06:21:08 PM »
can`t you use an anglegrinder and just start grinding till that layer is gone? It `s a loud and nasty option,  but all possible rust between them will be gone.  :dunno:
*** Bart ***
Offline JonS
« Reply #2 on: July 02, 2011 - 10:32:48 PM »
I'm pretty sure I had no trouble getting in there with a spot weld cutter (drill).  How big is the setup you are using?
« Reply #3 on: July 03, 2011 - 11:37:34 AM »
The only way is to go from the enginebay, no way to get in between the flooredge and the torquebox or whatever it is there. Another option is like Bart suggested, grind it down.
Per
Offline CHL2T
  • Handle it, man!
« Reply #4 on: July 05, 2011 - 08:55:19 PM »
How about an air chisel.......  :dunno:
Offline wagesofsin
  • just a sinner
« Reply #5 on: July 05, 2011 - 09:03:06 PM »
that front area is spot welded under the car. like previously stated, engine bay under is where to drill. a air chisel will suffice if need be, but due diileeance needs to be taken as to not destroy the firewall side of the panel. in other words, take your time and be patient.
think fast. move slow.
