Author Topic: what carb for a 360  (Read 1918 times)
Offline joef89
  • 74 Challenger RT
what carb for a 360
« on: July 02, 2011 - 05:41:32 PM »
im having problems with my carb running very rich so now im trying to find out what size i should use. right now im running a 650 edelbrock. but i want to get the most power i can get.
Re: what carb for a 360
« Reply #1 on: July 02, 2011 - 06:58:04 PM »
Is this a stock 360, or has it been built up some?
Offline joef89
  • 74 Challenger RT
« Reply #2 on: July 02, 2011 - 07:07:10 PM »
as of right now its basically stock. im gona put a little more aggressive cam set up in it and it has a edelbrock rpm intake. other than that it is stock
« Reply #3 on: July 03, 2011 - 12:54:15 AM »
I would be using Proform 750
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #4 on: July 04, 2011 - 09:58:16 PM »
i use a 600 edlebrock
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: July 04, 2011 - 10:08:37 PM »
sounds right to me...
Offline jimynick
« Reply #6 on: July 04, 2011 - 11:13:08 PM »
Joe, I agree with most of the guys here, I used to run a 735 or 750 Holley on my 340's and they worked well. Why is the Carter- 'cause that's what it is- running rich? Does the choke come off completely when it's warm? What is the fuel pressure at the carb? It should be 6-7psi-max. If the former are all kosher, then get a jet kit for the carb and step it down a couple of sizes at a time until it gets where you like. The carbs are very easy to service- lift off the top and the jets are right there. If you have access to a tailpipe sniffer, shoot for approx 14:1 air/fuel mixture at idle and 12.5-7:1 at power rpm. They're good carbs- Mother Mopar used them for years. Good luck :2cents:
Offline joef89
  • 74 Challenger RT
« Reply #7 on: July 05, 2011 - 10:21:01 AM »
Yea i had a 750 on there but decided to take it off and switch back to my 650. the 750 no matter how i tuned it just didnt have the power it seemed of the 650.  I still have to re jet my 650 and put a new power valve on and i believe that this should solve my problem. now its time to put the 750 back on my dads car.
Offline joef89
  • 74 Challenger RT
« Reply #8 on: July 05, 2011 - 08:22:32 PM »
Still not running right. tried putting that new power valve in the holly 650 then tried switching back to the 750 performance still running rich and now put on my old edelbrock 600 and even that runs rich. Were thinking the cam needs replacing seeing how we were gona do that anyways. any other suggestion before we go this extreme?
« Reply #9 on: July 05, 2011 - 08:30:59 PM »
What initial timing & total timing at what RPM are you running?
Offline jimynick
« Reply #10 on: July 05, 2011 - 10:39:26 PM »
Joe, the cam has zero to do with the car running rich. All carbs are running rich- check the fuel pressure and do you run with a regulator? The 650 probably ran better on a street car because of it's higher velocity which gives better mixture and ram effect. Do the basics and hopefully you'll find the problem.  :2cents:
Offline joef89
  • 74 Challenger RT
« Reply #11 on: July 05, 2011 - 11:29:53 PM »
the cam does effect the valve timing which with the the timing being off would cause it to run rich because it isnt breathing right. but have tried everything else so now its time to spend some money. i wanted to put new cams in eventually anyways.
the best vacuum i could get was by advancing the timing to the max (base timing 30 degres. total of 60 degrees at 2500 rpm) and only getting 18.2
« Reply #12 on: July 05, 2011 - 11:41:22 PM »
19 " of iz the best a stock cam could do , vacuum bear 12 " is lots . It is not low vacuum causing the rich problem
Offline Strawdawg
    • Vortex Buicks
« Reply #13 on: July 06, 2011 - 12:03:22 AM »
No, it is not.
« Reply #14 on: July 06, 2011 - 12:08:21 AM »
Timing doesn't sound right. Read this and consider your base timing & mechanical advance http://www.cuda-challenger.com/cc/index.php?topic=13018.msg132114#msg132114
I'm wondering if your primary's are not opened so much that your idling on the transition circuits.
