Author Topic: trunk battery, tape cables or not  (Read 4209 times)
Offline dutch
Re: trunk battery, tape cables or not
« Reply #15 on: July 09, 2011 - 01:12:27 PM »
I don`t know how to calculate from your american wire sizes to ours, but this size cable was adviced to me by a local batteryservice shop...  :dunno:   sure hope I got some good advice there, cables are already in and taped up...    Both + and - cables are double insulated neoprene, 35 mm2  in size. Can anyone here confirm this will be enough?   So dodj,  do you mean I should use a double ground? one to the front and one to the chassis near the battery?
*** Bart ***
« Reply #16 on: July 09, 2011 - 02:53:13 PM »
My Optima Battery is in the Trunk on the Passenger Side.
Welding Cables were used.
The Negative is Grounded in the Trunk.
No Problems.
Engine Bay looks a lot Cleaner and more room to work with no Battery up front.
Offline Strawdawg
    • Vortex Buicks
« Reply #17 on: July 09, 2011 - 04:07:20 PM »
That is basically 2 gauge...if you don't have a high compression engine and the starter does not get too hot, I would think it will work.  The cheap kits are often smaller than that
Offline dutch
« Reply #18 on: July 09, 2011 - 06:03:10 PM »
The 440 should have around 10.5: 1 comp.  Not sure if I will use manifolds or headers, but with headers I will use a hightorque starter.
Lights ,wipers  :grinno: , horns, and a 4x25w radio is my electric gear  :biggrin:
*** Bart ***
« Reply #19 on: July 09, 2011 - 11:01:06 PM »
Yes, that's what I mean. Same as what the factory did at the front. A #10awg (approximately 5 mm2) IMO would be sufficient.
Offline dutch
« Reply #20 on: July 10, 2011 - 04:06:34 AM »
thanks  :thumbsup:
*** Bart ***
