Sending unit
Author Topic: Sending unit  (Read 747 times)
Offline polarbear123
Sending unit
« on: July 03, 2011 - 12:28:17 PM »
I have a water leak at my sending unit on a mechanical water temp gauge. Any ideas on how to stop it?
Offline Strawdawg
    • Vortex Buicks
Re: Sending unit
« Reply #1 on: July 04, 2011 - 09:19:01 AM »
if it is leaking around the center of the sender, then I think replacement is your only real option
Re: Sending unit
« Reply #2 on: July 04, 2011 - 09:47:59 AM »
That’s what I thought but I was hoping. It is a new gauge and has been leaking since I put it in.  It is part of a 3 gauge cluster and cable is permanently attached to the temp gauge.
Offline Skunkworks Challenger
  • Mopars forever!
Re: Sending unit
« Reply #3 on: July 04, 2011 - 10:49:36 AM »
Remove the unit and check the back side.  You should be able to apply a sealer where the sensor enters the threaded bushing.  PK
The Brewmaster
Re: Sending unit
« Reply #4 on: July 04, 2011 - 04:21:24 PM »
I removed the sending unit applied teflon tape so that it hung below thread and coverd top of the sending unit. So far no leaks
Thanks
