Tail lights
Author Topic: Tail lights  (Read 674 times)
Offline polarbear123
Tail lights
« on: July 06, 2011 - 02:55:20 PM »
Having trouble with my tail lights 70 Cuda. When I put my turn signal on taillights go out. it doesn’t affect turn signal and brake lights . I was told it could be turn signal switch. How dose it affect the tail lights.
Re: Tail lights
« Reply #1 on: July 06, 2011 - 03:25:29 PM »
more likely to be a ground problem , make sure the housings arte grounded even if you have to connect a wire to ground , when the housings have no ground it will go to ground throught the tailights or side light circuit
Re: Tail lights
« Reply #2 on: July 06, 2011 - 04:35:50 PM »
It could be your turn signal switch. Both the tail lights and turn signals share the same filament in the bulbs. I was surprised when I replaced my turn signal switch how dry and crusty it was.
